Compression?
Old May 21, 2002 | 02:01 PM
95hybridcivic's Avatar
Default Compression?
Does any one know what the stock compression is on a 95 JDM B18C?
What is the Standard and Minimun numbers thanks in advance.
Old May 21, 2002 | 02:10 PM
zilverz's Avatar
Default Re: Compression? (95hybridcivic)
oh you mean cylinder compression ? ackkk i dont know that one .... i bet the values are in a Helms for the USDM version ... might be tough gettin the specs for a JDM b18c but i bet there similar
Old May 21, 2002 | 02:31 PM
gsr squirrel's Avatar
New User
Default Re: Compression? (zilverz)
10.6:1 c.r
dubster99's Avatar
10.6:1 for JDM SIR-G
11.0:1 for JDM spec R
Old May 21, 2002 | 06:04 PM
Default Re: Compression? (dubster99)
my bad i was not specific enough I mean the cylinder compression. If you know what it is for the US version that is close engough. thanks again
Old May 21, 2002 | 06:11 PM
ingrate's Avatar
25 Year Member
It's been a while but the all-data CD said 270 nominal and 135 is the absolute minimum for the USDM. Realistically most good running B18C1's are around 190-235. So anything in that vicinity should be pretty normal. Consistency is more important than super high numbers
Old May 21, 2002 | 06:37 PM
Default Re: Compression? (In7egrity)
Thanks a lot. I think last time i did the compression check they were at 175 but i am not positive. I am seeing bluish smoke come out the exhaust at high RPM's could 175psi compression cause this. thanks for the info.
Pullig
Jan 2, 2015 04:07 PM
twentyhurtz
Nov 17, 2009 04:58 AM
1993gsrcivic
Sep 27, 2007 12:21 PM
94TealGSR
Nov 30, 2002 10:12 AM
Cyber ITR
Aug 2, 2002 09:28 PM
