HELP! Code 54!!
Old Sep 15, 2002 | 05:02 PM
B00ST2nR's Avatar
Default HELP! Code 54!!
Ok. The Check Engine light went on again while I was driving to church. I got back home and jumped the wires to get the code and got a Code 54.
It says: CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
Ok. So what the hell does that mean? Someone please explain to me what that means and how I can fix it. Thanks.
Old Sep 15, 2002 | 05:35 PM
B00ST2nR's Avatar
Default Re: HELP! Code 54!! (Skunk2nR)
ttt
Old Sep 15, 2002 | 09:52 PM
vtec_racer_2kgsr's Avatar
I would like to help you, but I have no idea how to fix that...
try disconecting the battery to reset your computer
I'm the only one here that cares about a member!
Old Sep 16, 2002 | 05:06 PM
B00ST2nR's Avatar
Default Re: HELP! Code 54!! (vtec_racer_98GSR)
I just went downstairs to reset the ECU to get the CEL off, but to my surprise, when I turned the car on, the CEL was already gone!
Can it do that? It was one yesterday, and today, its gone. What happened?
Old Sep 17, 2002 | 09:12 AM
smkngsr's Avatar
that is the one located on the timing belt...u cant see it until u take that pulley out...is pretty expensive...i think 100 or more...if u havent replace an integra timing belt i willnot recommend u touching that part...hope this helps....try resetting ur ecu maybe it will go away...
Sephrin
Nov 10, 2009 04:24 PM
jetblack
May 16, 2006 06:20 PM
teg9
Dec 5, 2004 09:29 PM
spyderracing
Sep 30, 2004 05:59 PM
B00ST2nR
Sep 16, 2002 05:06 PM
