blue smoke??
Old Sep 17, 2002 | 09:50 PM
redteg1's Avatar
Default blue smoke??
my friend said blue smoke was coming out of my exhuast when i was "vtecing it" there is hardly any oil on my dipstick after changing it only 1k miles ago. whats wrong with my car?? the oil has been going low for a long time now even right after a oil change. and i can't figure out wat it is.
Old Sep 17, 2002 | 10:02 PM
ShiftDown's Avatar
Default Re: blue smoke?? (redteg1)
Blue smoke = burning oil =
How many miles on the motor? I'd say do a compression test and a leakdown test... you might have worn rings causing oil blow by. Worn valve guides also cause oil to get burned.... if this was the case then you would see blue smoke when deccelerating from high RPM's with the throttle closed.
david
Old Sep 17, 2002 | 10:04 PM
redteg1's Avatar
Default Re: blue smoke?? (Oki_Doki)
david
i currently have 106k on my gsr. i've tried differnt oil viscosity with no luck. i did a compression test and it came up 200, 210, 190, and 10. weird i kno.
Old Sep 17, 2002 | 10:13 PM
twotone's Avatar
looks like # 4 is done dude
Old Sep 17, 2002 | 10:16 PM
redteg1's Avatar
Default Re: blue smoke?? (twotone)
still ran a 14.9@93mph with i/e only on a 95gsr. i doubt its a dead cylinder...car runs perfectly fine. it was the second cylinder to the left btw
Old Sep 17, 2002 | 10:23 PM
tony4311's Avatar
10?!?!?!?! no way thats runnning perfectly fine, maybe the compression test was done with an error?
[Modified by tony4311, 7:23 AM 9/18/2002]
Old Sep 17, 2002 | 11:23 PM
IgniteTeg's Avatar
Default Re: blue smoke?? (tony4311)
10 is too damn crazy must be an error or its bye bye. I'd say test it again. Good luck.
Old Sep 17, 2002 | 11:36 PM
twotone's Avatar
Yeah it has to be a error if your running fine. Where did you have the test done and they should of tested it twice if it read 10. Good Luck
Old Sep 18, 2002 | 03:16 AM
Typiko512's Avatar
lol, I saw my exhaust spit some white smoke after racin with this audi a6 on the freeway the other night @ 145mph. what's wrong with that? friend said my ring is messed up but doesn't feel like it. any ideas.
Old Sep 18, 2002 | 03:19 AM
Acronym's Avatar
david
I agree
Old Sep 18, 2002 | 04:34 AM
redteg1's Avatar
we retested it like 4 times. same results. but how did my car run a 14.9 with only i/e after the compression testing? runs like how a normal gsr should. nothing feels different at least.
[Modified by redteg1, 1:44 PM 9/18/2002]
Old Sep 18, 2002 | 08:19 AM
Shark Tank's Avatar
you are burning oil. piston rings have probably gone bad. time for a rebuild or you can just keep adding oil to patch the problem, but eventually those rings need replaced. time for rebuild, have fun
Old Sep 18, 2002 | 10:15 AM
roydogg's Avatar
Default Re: blue smoke?? (CART fan)
I'm having the same problem and I know that it's the rings cause I just got the valve seals done about 2 months ago and I'm still burning oil but not as much as before.I really don't feel like coughing up the money to get the rings replaced but I know that I have to soon. Would it be okay to still spray nitrous until the winter time or would I make the motor even worse than it already is if I do? What's the average cost for rings and labor?
Old Sep 18, 2002 | 10:19 AM
redteg1's Avatar
Default Re: blue smoke?? (roydogg)
ok maybe the piston rings have gone bad...but then again maybe not. i changed my spark plugs about 4k miles ago and i found the first 2 spark plugs were flooded with oil. i resealed the valve cover gasket and everything seems to be fine last time i checked...no more flooding. all gaskets are fine, sealed, and fresh live rubber. but all is well now with the spark plugs. but im just wondering wat could've caused the oil to flood in like that also.
[Modified by redteg1, 7:20 PM 9/18/2002]
Old Sep 18, 2002 | 02:20 PM
twotone's Avatar
Man all I got to say about this is FUCKED UP I dont know how you car can run so good with low compresion must be all that NAWWZ you ******* mad man. It does sound like you need to rip it apart and rebuild. If money is an issue just keep adding oil and lay off on the nos if you want to strech the life of your engine. Good Luck Bro
Old Sep 18, 2002 | 03:20 PM
Db84DooR's Avatar
Your burning oil ! Maybe your piston rings are bad....
Old Sep 18, 2002 | 04:10 PM
Vertigo's Avatar
Default Re: blue smoke?? (Db84DooR)
Rings and/or piston (hopefully not your cylinder wall) need repairs.
Good luck
Old Sep 18, 2002 | 05:21 PM
Stewie's Avatar
Default Re: blue smoke?? (synchro)
white smoke could be synthetic oil burning.
Old Sep 19, 2002 | 10:47 AM
redteg1's Avatar
its not me using nos bro. thats roydogg. i don't have money for a rebuild
Old Sep 19, 2002 | 10:57 AM
mugenracer's Avatar
i would definetly say oil rings, did you run that time before or after having the comp test done, possibly the hard run finally killed that oil ring.
i was told but dont know if its true or not that constantly changing to different weight oils/brands will also kill seals/rings, so stick to the one oil till you get your problem sorted.
Old Sep 19, 2002 | 03:57 PM
redteg1's Avatar
Default Re: blue smoke?? (mugenracer)
ran that time after having the comp test done.
Old Sep 19, 2002 | 04:16 PM
Comp97GSR's Avatar
[QUOTE]looks like # 4 is done dude still ran a 14.9@93mph with i/e only on a 95gsr. i doubt its a dead cylinder...car runs perfectly fine. it was the second cylinder to the left btw[/QUOTE
Just to let you know, when I bought my GeeSR new(626 miles) ,it went through a quart of oil every week (about 300 miles) and she ran 14.9's also. I will tell you that if your compression numbers are correct you better fix it as soon as possible or you will ruin that cylinder..... just speaking from experience.
EDIT/ I needed new rings in #3 cylinder and the cylinder wall was ruined b/c I waited too long to get it fixed. New short block was ordered./EDIT
[Modified by Comp97GSR, 7:21 PM 9/19/2002]
Old Sep 19, 2002 | 04:29 PM
redteg1's Avatar
Default Re: blue smoke?? (Comp97GSR)
whoa...im not losing oil like THAT! a quart every 300miles?! thats crazy. im talking about just low on the dipstick like maybe every couple thousand miles or so
battosai
Aug 29, 2014 07:46 AM
j-bird20
Jan 11, 2007 05:59 PM
T25So
Sep 8, 2004 11:39 AM
roninb18
Feb 28, 2003 10:19 AM
Cyber ITR
Jan 7, 2002 05:10 PM
