Testpipe help
Old Sep 19, 2002 | 12:14 PM
TSAngry's Avatar
Default Testpipe help
i'm new to this and they finally let me post something. i have a 01 gsr and was thinking about getting a testpipe. my question is what should i do when the check engine light comes on because of the o2 sensor? i ask this because my friend used to have a hollowed out cat and his check engine light always went on. and also, what size testpipe would i need to get to fit my stock exhaust and headers?
Old Sep 19, 2002 | 01:16 PM
1nteg's Avatar
Default Re: Testpipe help (01GsR)
don't worry about the check engine lite. use 2.25" pipe, unless u gotta jdm 4-1 type r header, then u'll need 2.5" piping
Old Sep 19, 2002 | 01:24 PM
TSAngry's Avatar
Default Re: Testpipe help (1nteg)
what if the light comes on? how do i work around it so that it wont go on and bug me?
Old Sep 19, 2002 | 02:55 PM
neo1z's Avatar
well its going to go on no matter what, you have catylitic converter failure (obviously). you can always try the "plug up the holes and wrap up the o2 sensors really really tight trick", but i wouldnt.
Old Sep 19, 2002 | 06:13 PM
TSAngry's Avatar
Default Re: Testpipe help (neo1z)
thanks for the help. one more thing. if i just leave the sensor unwrapped will it eventually get damaged from the excess flows. and will having my check engine light on mess with any computer or ecu stuff that would change the performance of the car? thanks again for the help.
Old Sep 19, 2002 | 07:37 PM
TurboTurtleGSR's Avatar
I have a brand new test pipe for a 01 GSR that I never used. You can have it for $45.00 shipped if you're interested.
Old Sep 19, 2002 | 08:03 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Testpipe help (TurboTurtleGSR)
test pipes
wow, let's ruin the environment for shitty sound and .01 HP
Old Sep 21, 2002 | 02:37 AM
AccrdATK's Avatar
New User
Default Re: Testpipe help (dLo GSR)
i used to have a test pipe in my type r it should go on after a certain number of miles... i used to reset my ecu just so i dont have to see that stupid light... im not quite sure but i believe that it makes your car run in safe mode... i think it dumps more fuel cuz your ecu is thinkin your running lean or sumptin like that
Old Sep 21, 2002 | 06:07 AM
TimoneX's Avatar
New User
Default Re: Testpipe help (JdMR-536)
I've run one from time to time for short periods on my OBDIIa GSR. It turns on the CEL but doesn't send my car into "limp" mode. I'm not thoughtless about the consequences, but at the same time you don't see people whining about everybody buying these 80 ton eyesore trucks like the Ford ex-lax-cursion. These gas guzzling giant toasters dump pollution and smash the roads to crap costing everybody for road repair. Don't worry though Ford promises it WILL fit in your garage...with minor modifications. M1 tank anybody?
Old Sep 21, 2002 | 07:02 AM
RacerMike's Avatar
http://www.testpipes.com claims theirs don't throw a CEL...
Old Sep 21, 2002 | 09:50 AM
TimoneX's Avatar
New User
Default Re: Testpipe help (2000integragsr)
Yeah they don't smell fresh as a summer breeze. Perhaps you had a leak at the donut? It really isn't that bad without a leak.
Old Sep 21, 2002 | 09:54 AM
Anthony K's Avatar
New User
Default Re: Testpipe help (TimoneX)
Pull the o2 sensor into the cabin. Wrap it up nicely with aluminum foil. Zip tie the sensor down to something to hold it in place. No CEL's.
neo1z's Avatar
Default Re: Testpipe help (RacerMike)
well they are lying to their customers then
Old Sep 21, 2002 | 04:22 PM
TSAngry's Avatar
thanks for the help. i just might try out that foil and zip tie trick.
Old Sep 21, 2002 | 11:49 PM
RockDawg_GSR's Avatar
Actually i have a test pipe on my teg and it doesnt pull any codes.I have the jdm header with a 3"-2.5 test pipe.I have the secondary O2 sensor hole directly into the test pipe welded on. 2nd i wouldnt get a test pipe for a stock exhaust and stock header. Wait until you have done those mods 1st.
biggjerryc
May 17, 2008 08:56 PM
chinopr24
Jan 4, 2008 09:51 AM
BrianCivicDX
Oct 25, 2006 05:50 PM
krazykaraboo
Jul 24, 2004 10:51 AM
Memo6453
Feb 11, 2003 10:26 AM
