check engine light on after installing CAI
Old Sep 17, 2002 | 02:59 PM
bboychris's Avatar
Default check engine light on after installing CAI
after installing my cold air intake about a week later my check engine light came on, anyone know what this can be from or any tips on how to find out the problem, the "main req" dosnt pop on so if any has anytips let me know thanks!
Old Sep 17, 2002 | 03:24 PM
ragejed's Avatar
Default Re: check engine light on after installing CAI (b18c-one)
reset the ecu, if it comes back, check the code
Old Sep 17, 2002 | 04:48 PM
Deluzional's Avatar
Default Re: check engine light on after installing CAI (ragejed)
yea jus reset the ecu
Old Sep 17, 2002 | 05:38 PM
vteg's Avatar
New User
Yeah, like the others said
If that does not work you will have to check the code.
Old Sep 17, 2002 | 06:32 PM
lsteggy's Avatar
Default Re: check engine light on after installing CAI (vteg)
its because of the obd2 dont even worry about it.
Old Sep 17, 2002 | 08:52 PM
Thrillhouse's Avatar
Default Re: check engine light on after installing CAI (lsteggy)
make sure you plugged in the sensor then reset ecu.
Old Sep 17, 2002 | 08:56 PM
GSRaCeRbOI's Avatar
recheck the install/hoses etc.. then reset the ECU.. if you opt to reset by pulling your negative battery cable.. make sure you have your radio code... (if you still have your stock radio)...
rhdins
Jun 11, 2008 10:13 AM
crxaddikt
Dec 1, 2003 09:23 AM
ooooitswilson
Jul 28, 2003 11:02 PM
BigMig
May 10, 2003 06:01 PM
type Gendy
Apr 21, 2003 04:48 PM
