Should i boost?
New User
Well lets see, i have a 1995 Integra LS, and it has about 140,000 miles on it, and i was wondering if putting a turbo kit would be a wise idea. The miles on the motor are basically hogh-way miles, and it still runs great. I plan on boosting about 5-6 pounds daily diven, nothing drastic like 10 pounds. All input would greatly be appreciated. Thanks
u should be okay with that...just upgrade ur fuel management a lil...bigger injectors so on so forth
u might want to get rid of the cast pistons and rods for lower compression forged ones...its a lil $$$ tho
custom turbo is cheaper btw
good luck
good luck
New User
yeah injectors, fmu, and F-AFC is what ill be using for fuel.
Now i have an ITR exuast, should this be a problem with 5-6 psi? BTW ITR exuast's are 2.25'
LS motor = low compression
so...if you are going to go with forged pistons and rods do not go with lower compression pistons
Boost 7-8 psi and use a 3 inch exhaust
Even with 6 pounds I would say 3 inch exhaust. 3 inches from the downpipe all the way through the exhaust.
I can refer you to a guy who makes hella good turbo manifolds and dp's for hella cheap. PM me.
New User
i got a drag manifold already, and im only gonna boost no higher than 6 psi, what about a GREDDY SP exuast? 2.50.
Im not doing a rebuild anytime soon, so thats deff out of the question. I also have a brand bew street disc waiting to be installed with the kit.
we turbod one at 120k miles on it had no problems ran 13.1@105 till the owner stopped doing the proper maintenance, and then he started having problems, as long as your car was properly maintained, and has good compression i dont think you would have a problem, just take the time and do the install properly
proper maintenace would include...
belts...checking oil several times a week...checking all fluids several times a week...if you dont have a turbo timer, let the car idle for a couple of minuets before you shut it off once you reach your destination...check all your hoses, especially your oil lines, for any leaks, cracks, etc...keep everything nice and clean under the hood
supracharger19
10
Mar 18, 2010 04:13 PM
tonyboosted
22
Dec 21, 2009 03:45 AM
WangChung
16
Oct 5, 2003 05:03 PM
