205/50/15 psi?
Old 08-28-2003, 08:27 AM
gsrpilot8000's Avatar
Default 205/50/15 psi?
I was curious, what inflation psi do you guys have in your 205/50/15 tires (on stock rims)? I just ordered a set of 205/50/15 yoko es100's and wanted to know what performs best. Thanks for any replies.
Old 08-28-2003, 08:41 AM
dohc-nyne's Avatar
Default Re: 205/50/15 psi? (gsrpilot8000)
i have 40 psi in the rear and 30 in the front falken azenis 205 50 15
Old 08-28-2003, 08:43 AM
Bill Hook's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpilot8000 &raquo;</TD></TR><TR><TD CLASS="quote">I was curious, what inflation psi do you guys have in your 205/50/15 tires (on stock rims)? I just ordered a set of 205/50/15 yoko es100's and wanted to know what performs best. Thanks for any replies.</TD></TR></TABLE>
I'm running 2 PSI over stock recommendations for 195/55-15 ES100s. I'd start from there. Wider tires on the same rim width would mean that the sidewall is already flexed more, so you might give it anothe 2 psi over what I'm running.
Old 08-28-2003, 10:42 AM
Lord Helmet's Avatar
for me 33-35 PSI
Old 08-28-2003, 02:40 PM
R.S.'s Avatar
Default Re: 205/50/15 psi? (sleeperciv)
i run 3-4 PSI ova the stock recommendations for the GSR
Old 08-28-2003, 02:50 PM
TEXN3's Avatar
Default Re: 205/50/15 psi? (-R-)
the psi range sometimes differs between tires and definitely between sizes. check with the sidewall for the cold psi rating. add about 2-3 psi if the tires are warmed up(you can tell by putting your hand on the tread).
AiL45
12-22-2006 06:59 AM
FAWKeveryb0dy
08-14-2006 12:44 PM
tdo
11-09-2005 03:31 PM
Powered By Garrett
03-07-2005 08:13 AM
Ragezero76
07-13-2003 06:31 AM
Quick Reply: 205/50/15 psi?
