HELP!!
Old Aug 30, 2003 | 07:17 AM
GSRGuy17's Avatar
Default HELP!!
I have a '94 Integra GS-R. Stock engine, everything but the muffler is stock. My parents took off in the car this morning, and after about a block, the dash lights came on, power steering/brakes went out, and the car stopped. Windows, etc., still work. Engine turns over, but won't start, and shakes (rotates, if you know what I mean) on the mounts badly, like it's really trying to start. Timing belt is 30K miles old, there's no visible problems (fuse, hoses etc)... the car just won't start. Any help would be appreciated.
Old Aug 30, 2003 | 07:30 AM
mr.beeks's Avatar
Default Re: HELP!! (GSRGuy17)
check if you are getting any spark
pull one of the cables from the distributor and place it near the contact
and have someone crank it and see if any spark
if not its your igniter that you need to change..
Old Aug 30, 2003 | 07:40 AM
GSRGuy17's Avatar
Default Re: HELP!! (francisco flores)
contact as in where it was before I pulled it? Got it
Old Aug 30, 2003 | 07:41 AM
mr.beeks's Avatar
yeap as where it was connected before
but you want to see a spark jump thru
make sure you are holding to the insulated part of the cable.
or you be in for a nice shock.
Old Aug 30, 2003 | 07:56 AM
GSRGuy17's Avatar
ok... I did that... doesn't appear to be getting spark, at least not from what I could see.
Old Aug 30, 2003 | 08:01 AM
mr.beeks's Avatar
igniter
time to change it
its inside your distributor
Old Aug 30, 2003 | 08:27 AM
GSRGuy17's Avatar
ok... anything else? Car is a 94 with 167K miles
Old Sep 1, 2003 | 11:38 AM
GSRGuy17's Avatar
Just in case anyone cared, it was the ignition coil. Cost $150 to fix, took 30min at the shop Only thing that sucks was the $75 towing.
dirrtybirdy
Mar 28, 2010 01:43 PM
filet611
May 27, 2006 08:40 AM
jry2598
Feb 17, 2006 11:50 AM
ton_gu
Oct 24, 2004 10:05 PM
billyzakkus
Nov 17, 2003 07:10 AM
