ANOTHER tps question
Old Jun 6, 2004 | 02:36 PM
dcb16's Avatar
Default ANOTHER tps question
ok, i keep getting a cel 7. i checked my tps voltages and everything is ok. i reset the ecu (unplugged the ecu fuse and its backup) and i continue to get the CEL. Im not losing any significant amount of power but im idling around 750 rpm when the car is warm (i assume thats an acceptable number, just a little low). has anyone had this problem and what did they do about it? thanks. oh ya, its a gen 2 jdm b16.
Old Jun 6, 2004 | 03:01 PM
IVI's Avatar
IVI
Default Re: ANOTHER tps question (dcb16)
if its running fine, its not broken, than dont touch it.
if the cel is such an eye sore take out the bulb
your going to end up messing something up if your poking around.
Old Jun 6, 2004 | 08:43 PM
91DAveLS's Avatar
you might want to disconnect the battery...we have a JDM b16a SirII in our teg and i tried to reset the ecu with the fuse thing...didn't work..but i disconnected the battery and that did the trick. Good luck.
Old Jun 6, 2004 | 11:11 PM
dcb16's Avatar
Default Re: (TDaddy)
i did that too, same thing, but i have heard that sometimes the factory sets ecu's to set the check engine light to go off after Xxxx amount of miles, is this true for honda? and is there someway to clear the ecu's memory (other than disconnecting batter and ecu fuses)
Old Jun 6, 2004 | 11:25 PM
hondaeg8's Avatar
Default Re: (dcb16)
i bet the tps is broken. take if off and i bet the spring and the little black thing will fall out. this happened to my friends car. it kept throwing the tps code. the tps sensor looked fine and the volts read good, but when we took the tps sensor off, it was broken on the inside. he has a jdm ls motor. mine was broken too when i got my jdm gsr motor.
Old Jun 7, 2004 | 10:54 AM
dcb16's Avatar
anyone else got ideas?
Old Jun 7, 2004 | 11:06 AM
Hawkze_2.3's Avatar
Make sure it's not broken and then try another one that you know works and see if that makes the CEL go away....or maybe get one from a junkyard...
Old Jun 7, 2004 | 08:07 PM
dcb16's Avatar
Default Re: ANOTHER tps question (Hawkze_56)
any other ideas?
Old Jun 8, 2004 | 07:49 PM
dcb16's Avatar
anyone?
Old Jun 8, 2004 | 07:52 PM
Sack Master's Avatar
So did you try another onr or what? You are obviously getting that .5 volts at idle. Maybe try aother ecu. Check it out.
Old Jun 10, 2004 | 09:14 PM
dcb16's Avatar
Default Re: ANOTHER tps question (Sack Master)
btw, my speedometer is fucked up too, could the tps be the cause of this? sometimes it stays at 0 mpn and other times it is at the correct speed and other times it flails from 140 mph to 20 mph. anyone?
Old Jun 11, 2004 | 03:32 AM
IntEGNYC's Avatar
and get those TPS reports on my desk tomorrow morning
93ex4door
Sep 27, 2010 12:28 PM
93FastLs
Jul 14, 2005 09:02 AM
Super7
Jul 15, 2004 09:00 AM
es_squared
Apr 3, 2004 05:05 AM
tmg
Jun 24, 2002 06:17 PM
