Ls ??
Old Jun 7, 2004 | 10:06 AM
Lshatchy91's Avatar
Default Ls ??
I was wondering how to adjust the idle on a 90 ls engine
Old Jun 7, 2004 | 10:20 AM
jdmrex91's Avatar
Default Re: Ls ?? (Lshatchy91)
there's a bracket on the intake manifold that your throttle cable runs through with 2 bolts on either side of a clip just adjust it from there
Old Jun 7, 2004 | 11:09 AM
Lshatchy91's Avatar
Default Re: Ls ?? (jdmrex91)
ttt
Old Jun 7, 2004 | 11:50 AM
Dent Free's Avatar
Maybe you didn't understand "JDMREX91" "He was say'n to loosen the 2 10mm nuts on the throuttle cable, then slide the cable either left or right till the idle is just right ( around 700-800 )
This process might that a could of try's till you get good --- It is pretty easy though
After I posted I notice that they might be 12mm nuts <--- Edit ---
Old Jun 7, 2004 | 11:54 AM
Dent Free's Avatar
Also check the Throttle Body for dirt and check the Idle Control Valve on the back the Intake Man. ( the one with Two Coolant lines coming out of it ) Spray it out with a carb/throuttle cleaner I would recommend BG cause it has a little lube in the Cleaner that is good for the Valve.
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
Hackura
Mar 12, 2009 03:17 PM
Full Race A6
May 17, 2005 03:53 PM
stock97
Aug 14, 2003 10:14 PM
crx-si
10
Jan 30, 2003 07:26 AM
