Best Fluids...
Old Jun 8, 2004 | 07:44 AM
Dawsonb17a's Avatar
New User
Default Best Fluids...
What are the best fluids for the transmission and brake system?
I'm thinking about flushing my brake system before the big HighTach Mtn Cruise next month.
Also, I've never changed my transmission fluid before, so I was thinking maybe I should?
is Motul a good brand to get for the gear oil, or is Redline better.
And for brake fluid, Motel? Or something else?
Old Jun 8, 2004 | 08:33 AM
TeGGY_LS's Avatar
Default Re: Best Fluids... (Dawsonb17a)
im using redline and it works fine.......i heard gm syncromesh is good **** though
Old Jun 22, 2004 | 07:09 AM
Dawsonb17a's Avatar
New User
Default Re: Best Fluids... (TeGGY_LS)
bttt
Old Jun 22, 2004 | 07:20 AM
silver_nteg's Avatar
GM syncromesh is some good stuff. I used it and man it did wonders, but dont take my word for it, do a search and read the 100's of articles on the topic.
Old Jun 22, 2004 | 07:21 AM
MAV3RiCK478's Avatar
gm synchromesh friction modified or honda mtl for your tranny. i use honda.
Old Jun 22, 2004 | 07:30 AM
timmy8151's Avatar
Default Re: Best Fluids... (MAV3RiCK478)
If you dont Auto-X a good brake fluid is Valvoline Synpower. It has good Wet/Dry boiling points and is very reasonably priced.
Old Jun 22, 2004 | 07:59 AM
3.504's Avatar
Default Re: Best Fluids... (timmy8151)
may i recommend what honda recommends? honda MTF for tranny and honda dot 3 for brakes..... if not, i like gm syncromesh or a good 10w-30 conventional motor oil for a tranny and a symbol dot 3 brake fluid
Old Jun 22, 2004 | 08:40 AM
Dawsonb17a's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">If you dont Auto-X a good brake fluid is Valvoline Synpower. It has good Wet/Dry boiling points and is very reasonably priced.</TD></TR></TABLE>
and if you autox?
Old Jun 22, 2004 | 08:46 AM
3.504's Avatar
if you do auto-x i'd say a non-silicon based thicker fluid.... i dont remember which one is non-silicon based, i think dot-5 is... dont remember. but that'll work well and has a higher boil point, with some braided lines and a decent rotor/pad combo you'll do pretty good and wont have much fade
Old Jun 22, 2004 | 09:03 AM
ate super blue (or whatever its called) or motul 5.1 i heard is pretty good.
Old Jun 22, 2004 | 09:07 AM
Dawsonb17a's Avatar
New User
yeah I got some ATE Super Blue, thats going in soon
Old Jun 22, 2004 | 09:18 AM
G-bonic's Avatar
Hijacked
i use wut honda dealer use and it all works fine.. honda wouldnt do or use something that is not gud for their cars.... remember that !!!
Old Jun 22, 2004 | 09:21 AM
ChillOutWayne's Avatar
Default Re: Best Fluids... (Stock_LS)
GM synchromesh, non friction modified, soooo smooooth...
Old Jun 22, 2004 | 12:58 PM
3.504's Avatar
Default Re: Best Fluids... (ChillOutWayne)
could you use friction modified in an LSD equipted tranny? cause theres supposed to be some sort of friction modifier in an LSD equipted tranny
skhell
Honda Civic (2006 - 2015)
Jun 24, 2014 09:54 AM
Guimba
Suspension & Brakes
Feb 17, 2010 06:05 PM
jdmcivicferio
Apr 6, 2003 02:16 PM
-BlueGSR-
Oct 5, 2002 07:16 AM
InfamousRS
May 12, 2002 10:05 AM
