compression ratios?
Old Jun 6, 2004 | 10:28 PM
Gotta_get_a_Teg's Avatar
Default compression ratios?
if i have a 95 GSR and im planing on turbo down the road with more boost what would be a good compression for the new pistons i plan on getting? and what would be a good ones for also nitrious just for background info
Old Jun 6, 2004 | 10:33 PM
alfaaay's Avatar
Default Re: compression ratios? (Gotta_get_a_Teg)
Typically people that plan on boosting like to go with the search function. They can boost pretty well when using the search.
Old Jun 6, 2004 | 10:44 PM
xplanetearth420x's Avatar
Default Re: compression ratios? (alfaaay)
you have a lot to learn
start searching today!!
Old Jun 6, 2004 | 10:53 PM
shermanyang's Avatar
yes...search is your best friend at the moment. search and read all the info you can until you can't absorb anymore info, then make a plan of what you want, look up the things you want in your setup for info about them, then start asking your questions. this will help you in the long run.
trust me...this is what i did and it worked out well for me.
civickid03
Jan 28, 2007 12:55 PM
moehp
Jan 6, 2007 09:35 PM
StrikerX
Jun 17, 2004 09:28 PM
TerribleOne
May 17, 2003 12:53 AM
type autox
Oct 23, 2001 09:54 AM
