engine problems?
Old Jun 7, 2004 | 03:43 PM
aftergamex's Avatar
Default engine problems?
hellooo everyone. i read a few articles that was posted regarding engines not starting. i wanted to explain my problem here and see what you all thought what could be going on with my 94 integra ls.
the other day i was driving around, and at a stop light i ended up stalling out. when i tried to restart it turned and turned and turned but never caught. after about a minute of pumping the gas, and trying to start it, it finally caught and i was on my way. the other day when it wouldnt start, i had only had the car on for a few minutes, ran into the store came out and it gave me the same problem.. today, i went to leave and once again, turn turn turn, and after about a minute of trying it finally caught. today it was very hot out. so i dont know if that has anything to do with it, especially since i dont believe it was very hot the other 2 times it decided to give me problems. (starts up fine right now)
if anyone can give me some ideas of what could be wrong, id greatly appreciate it. thanks for all responses ahead of time.
Old Jun 7, 2004 | 04:23 PM
G1 TEGGY's Avatar
Default Re: engine problems? (aftergamex)
my teg did this a little while ago too, it stopped, but what i concluded from it was either a faulty fuel pump or a clogged fuel filter.. someone correct me if i'm wrong
Old Jun 7, 2004 | 04:25 PM
PLAGUED_DB7's Avatar
check your main relay...I had the same probs with my 91 civic hb....the relay needs to be re-soderd/ or replaced...its a pretty common problem.
Old Jun 7, 2004 | 07:39 PM
Keno20's Avatar
If it starts alright when the car is cold, but struggles when its warm it would most likely be the main relay for the fuel pump, in which case you need to get the contacts resoldiered.
Old Jun 7, 2004 | 07:48 PM
Sack Master's Avatar
Default Re: engine problems? (Keno20)
Check for spark or fuel if that happens again. Maybe pump problem or coil problem. Could also be vapor lock which does happen.
Old Jun 7, 2004 | 08:41 PM
IVI's Avatar
IVI
Default Re: engine problems? (Sack Master)
could also very well be the gas that you put in your car.
Old Jun 14, 2004 | 11:54 AM
Default Re: engine problems? (IVI)
yeah..stay away from arco and 76...there gas made my car idle like a fat chick tight rope walks..up and down ..I only use mobile and citgo...and havent stalled out since..
Old Jun 14, 2004 | 10:48 PM
Default Re: engine problems? (theplague83)
I don't know about LA but the rest of the nation citgo is about the worst gas you can use. The dirtiest crap I have ever laid my eyes on(test it sometime). I stick to chevron. Shell is also very good gas.
Old Jun 15, 2004 | 12:23 AM
IVI's Avatar
IVI
happend to me after i filled up with sunoco. i thought they were good, i stopped putting them in, replaced parts, did a tune-up, got hess, and the problem was fixed.
Old Jun 15, 2004 | 12:31 AM
You_Get_Vapors
Guest
Posts: n/a
BP 93 always and forever
Old Jun 16, 2004 | 08:25 AM
donnnster's Avatar
aftergamex, have you figured out your problem yet? I am having a very similar problem...I was driving my 94 integra and all of a sudden the accelerator stops responding...power windows die, signal lights dont work..seems like the only thing that worked was the hazards and brakes...so I pull over and try to restart and it fails for awhile..but then I get it to startup...I brought my car into a shop and they said a transmission fluid flush could do the trick while my friend who is a mechanic thinks its either the distributor or the fuel pump...I'm still not sure what to do to fix the problem...
fireflare
Sep 30, 2009 09:48 AM
horgad
Jul 7, 2008 11:52 PM
bpetruzzo
Jan 8, 2008 05:48 PM
djwest24
Oct 24, 2005 07:44 PM
