map sensor
Old Jun 6, 2004 | 08:31 PM
T-roy's Avatar
Default map sensor
Does the stock map sensor in a 94 Integra RS B18B1 detect boost, if so up to what PSI?
Old Jun 6, 2004 | 08:33 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: map sensor (T-roy)
What do you mean?
Yes it will. It will detect anything. But the the stock ECU will not be able to process anything other than negative to zero intake pressure. This is why your car will throw a code and most probably go into limp mode.
Using certain techniques (with the the help of an AFC or something similar), you can use it for boosting up to about 10 or 11psi.
For most boosting purposes though......no, you shouldn't use it....but you can.
Old Jun 13, 2004 | 08:13 PM
TurboTeG4's Avatar
Default Re: map sensor (shamoo)
With the gm map sensor and the vafc can u boost 15psi
krugozor
Feb 21, 2011 08:38 PM
SnailedEG
Jan 28, 2010 12:52 PM
B16Drag
Jan 25, 2006 06:59 AM
5thgen
Oct 17, 2005 07:11 AM
HiGhCaM
May 11, 2002 11:40 PM
