HEAD GASKET PROBLEMS????
Old Jun 7, 2004 | 09:20 AM
B17AGSR's Avatar
Default HEAD GASKET PROBLEMS????
I have a 94 GSR and I have noticed that the radiator keeps pushing the coolant into the resivior and filling it up. I have replaced the radiator, thermostat, and bled the radiator twice. I have also done a pressure test and there were no leaks. I think it could be the head gasket but I haven't seen and smoke and it hasn't overheated. I pulled the radiator cap off and no coolant was in it. I also replaced the radiator cap. I cannot figure out the problem and I was wondering if anyone has had a similar problem and could help me out. I just get some advice before i pull the head.
TIA
Old Jun 7, 2004 | 11:32 AM
SIK IN DA HED's Avatar
New User
unless youre seeing bubbles or oil in the coolant, its not the headgasket. are you positively sure theres no leak? maybe your radiator needs to be flushed out. you might want to make sure there is pressure in the coolant lines.
Old Jun 8, 2004 | 07:23 AM
JDMG2i's Avatar
Default Re: HEAD GASKET PROBLEMS???? (B17AGSR)
You should also see if you fan is working
Hellsing032
Honda Civic (2006 - 2015)
Jul 30, 2013 06:54 AM
spruman03
Honda Civic (2001 - 2005)
Jul 6, 2008 11:40 AM
dynastix9
Dec 18, 2005 06:33 AM
Db1 Supreme
Jan 6, 2004 11:51 PM
CRXSIR1
Jan 12, 2003 05:53 PM
