LS/VTEC?
Old Jun 5, 2004 | 04:24 PM
iNTEGRA-vibe's Avatar
Default LS/VTEC?
What is this LS/VTEC swap I keep hearing about. I know you guys must think this is a stupid question asked by a stupid person but that is why I'm asking this so that I can learn. Any explanations? Thanx.
Old Jun 5, 2004 | 04:35 PM
crx-r1's Avatar
Default Re: LS/VTEC? (iNTEGRA-vibe)
the ls/vtec swap is when you use a ls non vtec block and put a vtec head on it. such as a civic si head or a type r hear. they do this because the displacement of the ls block is a little bigger 112 cubic inches compared to the gsr or type r's 110 cubic inches. the added displacement results in more torque. does that ansewer your question
Old Jun 6, 2004 | 11:29 AM
Default Re: LS/VTEC? (crx-r1)
Yes thank you for the information. That answered my question. I appreciate it.
Old Jun 7, 2004 | 03:29 PM
So which engine would be better? An LS/VTEC or GSR VTEC? What are the Pros and Cons of Both?
Old Jun 15, 2004 | 12:59 PM
crx-r1's Avatar
if you really want to build a bad *** motor i would go with a ls block and a type r head. throw in a set of type r pistons and it will be really fast
Old Jun 15, 2004 | 01:12 PM
nickgmiller04's Avatar
gsr motors have vtec stock.
hit the search button, type in "lsvtec" and "ls/vtec"
youll get 800 results
Old Jun 15, 2004 | 01:16 PM
redrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iNTEGRA-vibe &raquo;</TD></TR><TR><TD CLASS="quote">So which engine would be better? An LS/VTEC or GSR VTEC? What are the Pros and Cons of Both?</TD></TR></TABLE>
if you can get a gsr i would just get it and spend the money you would have spent buildig ur ls/vtec on the gsr. You will save yourself alot of headaches bc unless you know what your doin ls/vtec can end up bein more trouble than its worth
Old Jun 15, 2004 | 04:24 PM
krucial7integra's Avatar
Default Re: LS/VTEC? (redrex)
LS/VTEC is a monster when built correctly, but what would be even better is CRVTEC ( B20/VTEC ). But all depends on your goals
Old Jun 17, 2004 | 10:43 PM
aight thanx guys for your help.
Old Jun 17, 2004 | 11:25 PM
TurboTony's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-r1 &raquo;</TD></TR><TR><TD CLASS="quote">the ls/vtec swap is when you use a ls non vtec block and put a vtec head on it. such as a civic si head or a type r hear. they do this because the displacement of the ls block is a little bigger 112 cubic inches compared to the gsr or type r's 110 cubic inches. the added displacement results in more torque. does that ansewer your question</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krucial7integra &raquo;</TD></TR><TR><TD CLASS="quote">LS/VTEC is a monster when built correctly</TD></TR></TABLE>
Old Jun 18, 2004 | 12:19 PM
crx-r1's Avatar
Default Re: LS/VTEC? (krucial7integra)
the b20 has thinner cylinder walls than an ls motor it would be better to sleeve a ls block
chargedek
Dec 22, 2005 04:27 PM
shinji666
Aug 20, 2004 12:22 AM
99lsvtecauto
Nov 16, 2003 03:09 PM
ebelp
Mar 26, 2002 09:22 PM
integra81
Nov 22, 2001 04:11 PM
