nitrous
Old Jun 8, 2004 | 10:22 AM
JAYGSR's Avatar
Default nitrous
i have a 94 gsr my question is my ecu is chiped and advances timing now
can i still run with nitrous or not. what will happen
Old Jun 8, 2004 | 10:30 AM
zad5's Avatar
wut kinda chip usually chip dump fuel and retard the timing manually with the distributor u mite be good wut kinda chip u got
Old Jun 8, 2004 | 10:38 AM
JAYGSR's Avatar
not sure but rev limt is 10000 and vtech 5500
no speed govener. bought car with ecu chiped
previous owner dont remeber chip namebrand
Old Jun 8, 2004 | 10:48 AM
Si Erik's Avatar
Default Re: (JAYGSR)
I know this isn't the answer to your question, but first of all it's VTEC, not VTECH, and second off I really hope you're not taking your car to 10,000, especially if you don't have cams or any sort of valvetrain, cuase if you are you could be really ****** something up.
Old Jun 8, 2004 | 10:57 AM
GsrGilbert's Avatar
Default Re: (Si Erik)
if you really need to ask this question u need to do some more <U>research</U>. key word in that is <U>search</U>. dont risk blowing up another teg due to lack of knowlege.
Old Jun 8, 2004 | 12:50 PM
zad5's Avatar
yo doode basically it works like this u can do 50 shot for sure im not sure if u want to do any more. u can most likely do wutever the stock block can handle as long as u retard timing. i dont know why everyone is always asses to noob seems like a decent question to ask he has a chipped ecu where he doesnt even know the name and wants to know if it would work i think its a valid question. just retard ur timing get some colder spark plug maybe open up ur ecu and see if it says anything on the chip but u dont have to i believe u should be good to go.
Old Jun 8, 2004 | 01:07 PM
PMP_C_TEG's Avatar
you don't even know enough about your own car to be able to have a car with n2o. One chips are most of the time a waste of money, and by what you said so is yours.
1. Why 10,000 unless you have hella supporting mods you will never do any good being that high in the rpm range
2."no speed governer" well I hope the owner knew there never was a governer on any g3 integra.
Old Jun 8, 2004 | 01:49 PM
xplanetearth420x's Avatar
Default Re: (PMP_C_TEG)
you can put nitrous in anything of course its not always good for it
BlackOnBlackTeggie
Feb 1, 2005 10:10 PM
cliff666
Nov 10, 2003 05:26 AM
dvp95
Aug 20, 2003 05:31 AM
typesguy
Aug 6, 2003 09:07 AM
