Swap it or built it??
Old Jun 22, 2004 | 05:55 PM
JDMkidGSR's Avatar
Default Swap it or built it??
Look im new here on the board and i signed up for a few questions and would appreciate it if you guys can help.
I wanted to swap out my motor to a JDM b16a2(XSi Integra), but in the houston imports forums they recommended me to built my b18a. So what do you guys recommend me doin?Thanks
Old Jun 22, 2004 | 05:59 PM
Bseriescivic5's Avatar
build it, there is SOOOOOOOOO much potential for that motor......build it for boost and you hit 13's all day long.....
Old Jun 22, 2004 | 06:08 PM
AngelTeg's Avatar
Default Re: Swap it or built it?? (92bluteg_ls)
you dont want a B16 in an integra... not enough displacement, not enough torque. leave the B16s for the civics and crxs... keep the One Eight in the Integra...
-Mike
Old Jun 22, 2004 | 06:14 PM
Sack Master's Avatar
Default Re: Swap it or built it?? (AngelTeg)
Don't downgrade engines even if the 1.6 has some vtec. Build that, maybe throw a b16 head on it.
Old Jun 22, 2004 | 06:49 PM
JDMkidGSR's Avatar
nah i want it all motor, for a built what would you guys recommend. To run atleast low 14's or maybe even 13's.(On full interior and street tires) Is that possible if it is what ill i need. Thanks
Old Jun 22, 2004 | 06:57 PM
Default Re: (92bluteg_ls)
LSVTEC ENOUGH SAID!!! You'll lose a lot of torque capabilities with a b16 unless you want to stroike it. But why would you want to do that when you have a b18? And if you want a stroker motor you can still go bigger with the b18.
Old Jun 22, 2004 | 07:12 PM
JDMkidGSR's Avatar
well what do you all recommend me gettin but just for the b18a. Such as pistons, rods, valves, cams, valvetrain,etc.
Old Jun 22, 2004 | 10:39 PM
JDM civic master's Avatar
i like crvtec or b18c5, k20a2 myself
Old Jun 23, 2004 | 04:35 AM
TEGME's Avatar
Default Re: Swap it or built it?? (Dumptruck Sal)
Definitely Build
Old Jun 23, 2004 | 09:39 AM
Soy Bean's Avatar
buy a OBD1 B18C longblock and swap it in.
Old Jun 23, 2004 | 09:42 AM
babyteg's Avatar
build it
Old Jun 23, 2004 | 09:47 AM
Soy Bean's Avatar
Default Re: Swap it or built it?? (babyteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">'You can't polish a turd.'</TD></TR></TABLE>
hahahah... keep it and build if you plan to boost.
Old Jun 23, 2004 | 10:20 AM
redrex's Avatar
Default Re: Swap it or built it?? (DC2.NA)
a nice all motor build might b p30 pistons, crower 403s, pnp, skunk 2 im, basic boltons
thats if ur not goin lsvtec
Old Jun 23, 2004 | 10:34 AM
JDMkidGSR's Avatar
thanks for the replies, I myself was thinking of boring out my engine to 85mm with a 12:1 Compression pistons, some crower 403 cams, crower valves, titanium retainers, dual valve springs, 3 angle valve job, fully pnp head, i have already aem cam gears just not tuned, plus the things i have on already (greddy evo muffler, custom 2.25' in. cat back piping, tenzo r intake, nology hot wires, ngk spark plugs, aem cam gears, bbk fuel pump, bnm short shifter, hi-flow cat, centerforce d. friction clutch but its already fucked up so im gonna with ACT street/strip clutch w/ a 12lb. flywheel)With all these things what do you all think ill be running?
Old Jun 23, 2004 | 10:47 AM
Devlins 91LS's Avatar
6.432@285.36
Old Jun 23, 2004 | 11:14 AM
JUN1OR's Avatar
Default Re: Swap it or built it?? (Devlins 91LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devlins 91LS &raquo;</TD></TR><TR><TD CLASS="quote">6.432@285.36</TD></TR></TABLE>
hahaha
Honestly, there's no way to tell.
There isn't even a good way to tell what you'll be running. Every setup is different, and every method of installation and maintenance is different as well.
I will tell you this though. To get into the 13's with full interior and street tires, you are going to need a lot of cash. That's about all I can guarantee.
Back to the original question? As a proud owner of a gsr, I bet you'd think I'd say swap it, but nope. BUILD IT. Lots of potential in that motor. If you're going to stroke it, you might as well save the cash and start with a b20z.
I have a 94 B18b1 civic thats as fast as my gsr. And they both have similar amount of boltons!
It's the weight my friend. My integra needs to go on a diet.
Good luck in your endeavors regardless!
-Junior-
Old Jun 23, 2004 | 02:32 PM
redrex's Avatar
Default Re: Swap it or built it?? (JUN1OR)
if what your after is a low timeslip your goin to need a different transmission
Old Jun 23, 2004 | 02:38 PM
tC_Dragon's Avatar
Default Re: Swap it or built it?? (redrex)
Build it, swap it, you have potential to make signficant power gains in either. HOwever, i would not seriously consider swapping to the 1.6. Albeit, i think your chances of reaching your goals are far greater swapping in & building a b18c as suggested by some of our members here.
Qatar s2000
28
Feb 25, 2012 09:08 AM
b91da
Aug 22, 2011 12:25 AM
RockyMtnTEG
Apr 23, 2007 01:46 PM
Shua derson
Dec 19, 2002 10:37 AM
mr.sparkle
Sep 19, 2002 08:13 PM
