Transmission problems, need help please!
Old Jun 23, 2004 | 02:24 PM
T3-T4TEG's Avatar
Default Transmission problems, need help please!
well I put my new motor in a couple nights ago, I back out of the drive way and the clutch grabbed the flywheel fine. Then I tryed to drive in first gear and when i let out the clutch it wouldnt grab the flywheel. I tryed starting in second and the same thing happened. Then I realized I should just get it back to my house, so I put it in reverse and it wouldn't grab now. I don't understand why its doing this, I was just wondering if anyone had any suggestions. thanks
Old Jun 23, 2004 | 04:01 PM
JDMotive's Avatar
Default Re: Transmission problems, need help please! (T3-T4TEG)
Have you checked to make sure the slave cylinder isnt getting stuck?Did you replace the clutch before the swap?
Old Jun 23, 2004 | 08:36 PM
wreckedmyteg's Avatar
Check to make sure your axles are in all the way. Ask JUN1OR about that one...
immalooser
Apr 14, 2010 08:01 PM
bombjester
Jan 27, 2010 03:19 PM
HS2G
Aug 22, 2004 08:45 PM
OneThirtyEight
Jul 5, 2001 08:18 AM
