94-97 to 98-01 Difference?
Old Jun 24, 2004 | 11:22 AM
phil's Avatar
Default 94-97 to 98-01 Difference?
Flame me cuz I'm a noob, but what are the differences between integras from 1994-1997 and 1998-2001? There is a difference right? Cuz they look the same.
Old Jun 24, 2004 | 11:27 AM
Vi3tboy's Avatar
Default Re: 94-97 to 98-01 Difference? (phil)
go to team-integra.net. they have an article on it.
but some are body wise front end is different. headlights are angled deifferently. tailights have no amber turnsignals, rear bumper is different.
Old Jun 24, 2004 | 11:48 AM
patdemps's Avatar
Default Re: 94-97 to 98-01 Difference? (Vi3tboy)
The entire front bumper is different, the headlights are bigger, the rear bumper as stated above is different, 94-95 have obd1, 96+ up have obd2, the wheels change with years.....
you should really do a search. this has been covered on honda-tech many times aswell as team-integra.net
Old Jun 24, 2004 | 12:03 PM
debogsr's Avatar
Default Re: 94-97 to 98-01 Difference? (patdemps)
dont forget the mirror's also. steering wheel is different. The front seats are slightly different. The 94-97 have a key hole for the hatch, the 98+ have a latch in the handle. uummmmm?
Old Jun 24, 2004 | 05:29 PM
Pb Foot's Avatar
Default Re: 94-97 to 98-01 Difference? (debogsr)
In 97 or 98 and up, there are tweeters in the door panels... the list goes on... like someone mentioned, check out team-integra... there is plenty of info there
Old Jun 24, 2004 | 08:07 PM
phil's Avatar
Thanks guys. Quite a few differences I never knew about.
Old Jun 24, 2004 | 08:09 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 94-97 to 98-01 Difference? (Pb Foot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pb Foot &raquo;</TD></TR><TR><TD CLASS="quote">In 97 or 98 and up, there are tweeters in the door panels... the list goes on... like someone mentioned, check out team-integra... there is plenty of info there </TD></TR></TABLE>
Huh? All years have tweeters on the door panels, at least on some models. My 94 GS-R has them, factory.
*edit* also the mirrors changed in 96, not 98.
Also the factory muffler tip changed in 98.
A major underhood difference between 94-97 and 98+ is the change in the ABS system. 94-97 had a completely separate ABS system w/ its own reservoir and everything, and a large pump. In 98, with the introduction of the option of HID on the JDM Type R's, they switched to smaller ABS pump to make room for the ballasts on those headlights. The system was also integrated into the main brake system, with both systems sharing the same brake fluid (no separate reservoir for the ABS system on 98+).
Old Jun 24, 2004 | 08:43 PM
crawdad689's Avatar
Default Re: 94-97 to 98-01 Difference? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
A major underhood difference between 94-97 and 98+ is the change in the ABS system. 94-97 had a completely separate ABS system w/ its own reservoir and everything, and a large pump. In 98, with the introduction of the option of HID on the JDM Type R's, they switched to smaller ABS pump to make room for the ballasts on those headlights. The system was also integrated into the main brake system, with both systems sharing the same brake fluid (no separate reservoir for the ABS system on 98+).</TD></TR></TABLE>
oh he's just soooo knowledgable
good **** man
scobaru
Sep 20, 2019 04:51 AM
3cyltrbo
May 29, 2014 02:10 PM
DC2_2
Aug 19, 2006 09:57 PM
ATgrills.com
Feb 25, 2003 02:32 PM
tommyboy
Sep 19, 2002 02:54 PM
