Engine wants to die.....Help!
Old Jun 23, 2004 | 10:22 AM
wardstar's Avatar
Default Engine wants to die.....Help!
Hey everyone.
I've got a problem that's been happening for a while and i can't seem to figure it out. Every so often when i BEGIN to drive the car, i'll feel the engine want to die on me....I'll have to push the clutch in an give it gas.....Now the car never actually dies.....but it seems like it is almost going to...there's no power and i can hear it starting to shut down...But after about 5 minutes of driving it never happens again....A very weird problem...anybody experience this before? Where should I start? I've just replaced the airfilter with a aem cold air intake and the problem still persists.....Thanks in advance everybody.
Old Jun 23, 2004 | 10:24 AM
G1 TEGGY's Avatar
Default Re: Engine wants to die.....Help! (wardstar)
if you installed the AEM CAI you're gonna have to reset the ECU and tune it from there, but if it's bogging, i've seen this problem come up a few times and it's always been hydrolocking from something leaking into the cylinders from the coolant cycle. If it's not bogging you might just have a low idle problem, easily fixed
Old Jun 23, 2004 | 10:49 AM
Devlins 91LS's Avatar
Default Re: Engine wants to die.....Help! (G1_TEGGY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G1_TEGGY &raquo;</TD></TR><TR><TD CLASS="quote">if you installed the AEM CAI you're gonna have to reset the ECU and tune it from there</TD></TR></TABLE>
Did this guy just say that?
:scratches head:
Do a tune up, cap/rotor/plugs and that should prob fix it.
Old Jun 23, 2004 | 11:37 AM
G1 TEGGY's Avatar
Default Re: Engine wants to die.....Help! (Devlins 91LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devlins 91LS &raquo;</TD></TR><TR><TD CLASS="quote">
:scratches head:
Do a tune up, cap/rotor/plugs and that should prob fix it. </TD></TR></TABLE>
yes in fact i did, anytime you install a new mod you need to reset the ECU you should know that
Old Jun 23, 2004 | 11:17 PM
wardstar's Avatar
Thanks man....That's what i was thinking....No coolant leak in the oil....probably just needs some new plugs and stuff...And the problem started before i installed the new intake.....Can you give me some name brands to look for when replaceing plugs and wires, etc...
Thanks man.
Old Jun 24, 2004 | 06:22 PM
G1 TEGGY's Avatar
NGK or Bosch, i run bosch platinum 2's
kim_performance
Honda CR-V & Element
16
Mar 10, 2019 04:43 AM
E Swift
Feb 11, 2004 05:33 PM
DanishR
Jul 28, 2003 01:19 PM
jabenne
Apr 4, 2002 05:50 PM
Volcom
Jan 17, 2002 06:30 AM
