adjusting 98+ headlights
i tried moving the dials w/ a no 2 screwdriver, but the light doesnt move. im trying to adjust the horizontal angle, but it doesnt do anything. i did about 20 full rotations and it did not change. help? thx
Re: adjusting 98+ headlights (C. FujiMoto)
20 full rotations of the screwdriver? or 20 full rotations of the gear wheel? 96 and up have an 8mm hex head I think on the gear wheel, but it will probably require something like a ratcheting gear wrench to be able to use that to adjust, due to space limitations. That will be ablot faster than a screwdriver.
Re: adjusting 98+ headlights (PatrickGSR94)
http://www.team-integra.net/se...D=388
u have to be registered to use team-integra.net
New User
Re: adjusting 98+ headlights (Brand)
for the 98+ headlight, I parked about 30Ft away, and turned 30 times clockwise(vertical adj) before I saw any changes. Give it a few more spin, Otherwise, the headlight adjustment unit may have been damaged.
Re: adjusting 98+ headlights (acuraLSSE95)
yeah i had this problem and ended up leaving it messed up for awhile. but you just need to spin some more. i sat there and spun the damn thing for 10 min and thats when i started to notice movement. so i think just take your time. plus you may want to look at this site, gives you a good description on how to:
http://www.autooptiks.com/aiming.html
goodluck
goodluck
Re: (C. FujiMoto)
Adjusting your headlight can be very time consuming and frustrating it is also very easy to throw all the adjustment settings out of spec. If I were you I would take it in to the dealership and have them adjust it. It can't be that expensive.
Re: adjusting 98+ headlights (kendogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kendogg »</TD></TR><TR><TD CLASS="quote">im having trouble as well bump for us!</TD></TR></TABLE>
me too
me too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brand »</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...D=388
u have to be registered to use team-integra.net</TD></TR></TABLE>
thats waht i did, also shows u how in the car manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">20 full rotations of the screwdriver? or 20 full rotations of the gear wheel? 96 and up have an 8mm hex head I think on the gear wheel, but it will probably require something like a ratcheting gear wrench to be able to use that to adjust, due to space limitations. That will be ablot faster than a screwdriver.</TD></TR></TABLE>
about 20 w/ the dial.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk »</TD></TR><TR><TD CLASS="quote">Adjusting your headlight can be very time consuming and frustrating it is also very easy to throw all the adjustment settings out of spec. If I were you I would take it in to the dealership and have them adjust it. It can't be that expensive.</TD></TR></TABLE>
i would like to see where im going.
loki2323
01-16-2005 11:30 AM
