help please
Old Jun 21, 2004 | 03:12 PM
gsrboi80's Avatar
Default help please (suspension ?)
My friend has a 00 SI he's parting out. Will his Apexi N1 Dampers fit on my 00 GSR. Let me know asap. He wants to get rid of every thing asap.
Old Jun 21, 2004 | 03:28 PM
gsrboi80's Avatar
Default Re: help please (gsrboi80)
bump
Old Jun 21, 2004 | 03:48 PM
gsrboi80's Avatar
bump bump
Old Jun 21, 2004 | 03:56 PM
MaskedAP1's Avatar
NO. DC=EG
Old Jun 21, 2004 | 04:00 PM
gsrboi80's Avatar
Default Re: (MaskedDC4)
anyone else. I was pretty sure they would fit but I guess not. So what is the difference between the two
Old Jun 21, 2004 | 04:22 PM
gsrboi80's Avatar
Default Re: (gsrboi80)
ok whats the deal here my local import shop says they will fit but spring rates might be different. So what the hek is going on here
Old Jun 21, 2004 | 04:29 PM
2k1 SSM GSR's Avatar
different spring rates.
compare Tein SS Damper
DC2: F = 8/448 kgf/mm R = 6/336 kgf/mm
EM1: F = 8/448 kgf/mm R = 4/224 kgf/mm
Old Jun 21, 2004 | 04:31 PM
gsrboi80's Avatar
Default Re: (2k1 SSM GSR)
so that means they will work
Old Jun 21, 2004 | 04:38 PM
MaskedAP1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k1 SSM GSR &raquo;</TD></TR><TR><TD CLASS="quote">different spring rates.
EM1: F = 8/448 kgf/mm R = 4/224 kgf/mm</TD></TR></TABLE>
not only spring rates.. Ek suspenion wont fit DC... DC and EG,Del Sol r interchangeable.
someone pls confirm this thus the guy can believe me
Old Jun 21, 2004 | 05:02 PM
gsrboi80's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaskedDC4 &raquo;</TD></TR><TR><TD CLASS="quote">
someone pls confirm this thus the guy can believe me</TD></TR></TABLE>
i believed you but as i was searching I called local tuner garage and they said they would fit so then i didnt know what to believe
Old Jun 21, 2004 | 05:17 PM
MaskedAP1's Avatar
http://www.apexi-usa.com/suspe...s.asp
seems like different part number
Old Jun 21, 2004 | 05:24 PM
gsrboi80's Avatar
yea theres not even an application for my car. Somone from the civc forum just said that all I have to do is shave down the rear lca bushings because the rear shock forks are a little narrower on an ek civic than on a gsr
Blizzard
Suspension & Brakes
Jul 7, 2006 06:25 PM
The Jacko
Suspension & Brakes
Jan 31, 2006 01:44 PM
mattjohnston
Sep 24, 2004 12:14 PM
vti444
Dec 8, 2003 02:07 PM
