Cluster Question...
Old Jun 23, 2004 | 11:37 AM
xJ.SLOTHx's Avatar
Default Cluster Question...
are LS and GSR cluster plugs the same? as far as plug and play and being interchangeable? the reason why im asking is i have a 94cx and i plan on putting a JDM ITR Cluster and can get some LS plugs. thanks in advance.
-ian
Old Jun 23, 2004 | 11:42 AM
G1 TEGGY's Avatar
Default Re: Cluster Question... (ian)
i'm almost 100% sure that all the plugs are the same, i know the speedo is different from hydro to cable trannys, but the plugs should be the same, someone correct me if i'm wrong please
Old Jun 23, 2004 | 11:46 AM
xJ.SLOTHx's Avatar
Default Re: Cluster Question... (G1_TEGGY)
well in that case it should be fine then since im dealing with nothing but hydro setup trannies/cars anyway..thanks.
-ian
Old Jun 23, 2004 | 12:25 PM
SonicBlueTeg's Avatar
if you have a jdm cluster u will still need a usdm ls or gsr cluster cuz the wirings are different.. they are not directly plug and play..
jdm itr cluster swap into my gsr. album i made.. http://www.imagestation.com/album/?id=4289266009
it basically involves either moving each of the four(temp/gas/rpm/speedo) gauge sections from jdm to usdm housing.. or swapping the back green portion from the jdm to the usdm cluster.. if u just use the plugs and expect it to plug and play.. in an integra all the gauges would go nuts and not read correctly..
you also need to find a cluster with the same year as your car.. since u have a CX?.. i'm not sure which one you would use.. that might depend on your ecu? but i'm not even gonna guess on that one..
for integras.. if u have a 94-97 teg you would use a 97 or older jdm cluster.. & if u have a 98-01 teg you would use a 98+ jdm cluster.. if you had the wrong year cluster in your car even after u swapped the gauge sections to the usdm cluster.. that would also make the gauges not function properly...
hope that helps a lil..
Old Jun 23, 2004 | 12:59 PM
G1 TEGGY's Avatar
Default Re: Cluster Question... (SonicBlueTeg)
thank you for the correction and the info
Old Jun 23, 2004 | 01:08 PM
IntEGNYC's Avatar
the clusters vary by year depending on whether ist ODBI or ODBII, Auto versus Manual, etc....
Old Jun 23, 2004 | 10:48 PM
xJ.SLOTHx's Avatar
thanks for the replies. but what i plan on doing is swapping in a JDM ITR cluster into my 94' Civic CX. So I'll be acquiring a DC2R cluster soon but i was wondering if it made a difference whether i got LS, GSR or ITR plugs to plug into the cluster. and for instance if i got 94'~97' plugs...would they be able to plug into a 98'+ cluster??thanks.
-ian
rocketkev
Mar 4, 2009 05:55 AM
Weak!EG
May 7, 2007 09:07 PM
cltitus
Mar 15, 2007 07:41 AM
BlueIntegraBoy
Feb 17, 2004 09:56 PM
JasonNagra
Sep 30, 2001 08:14 PM
