HELP removing wheel stubs
Old Jul 18, 2004 | 05:08 PM
dxtc2go's Avatar
Default HELP removing wheel stubs
1995 acura integra ls with abs
I've never replaced my wheel stubs on any of my vehicle. Its very basic though but I think I may need some sort of machine to finish the job. I have gottin all the way up to removing the 32mm then I'm at the last plate that holds the stubs. I can't just hit the old stubs out. I have to get that plate off then I can remove the stubs and replace. How would I go about removing the last plate that holds the stubs. If anyone has any detailed information or any DIY with pictures, please send. I would greatly appreciate all help. Thank you. Please email me.
dxtc2go@aol.com
Old Jul 19, 2004 | 05:35 AM
JimBlake's Avatar
Default Re: HELP removing wheel stubs (dxtc2go)
Since you mention the axle nut, I know you're talking about the front. That 'plate' is the hub (#5), & there's more to it than just pulling it off...
You'll probably want to separate three ball joints: upper, lower, & steering tie rod. Take the steering knuckle out of the car, with the wheel bearing & hub still attached.
Press the hub (#5) out from the wheel bearing (#4). This usually destroys the bearing, since the outer cone usually comes out with the hub. If you don't have a press, carry the knuckle to a shop. Press the broken wheel studs out & replace them. Press a new bearing & hub in the knuckle & put it back in the car...
Ritchie
23
Jun 8, 2007 12:53 PM
Sijray21
Feb 28, 2006 08:33 AM
Pompiuses
Sep 12, 2005 06:57 AM
ITR-00-1457
Dec 14, 2004 02:38 PM
Lynx
Aug 10, 2002 04:13 PM
