blinker problem
Old Jul 18, 2004 | 11:24 AM
gsr-2nr's Avatar
Default blinker problem
1st YES i tried searching but found nothing that helped me. my blinker on the front passanger side is blinkng fast thelarge bulb is. i replaced the bulb a couple of weeks ago and it stopped but when i went to work this morning it started again and now the bulb itsnt working and i put 2 different ones in there and the large bulb is getting no power. and every other bulb works but this doesnt. what is wrong the harness is in i disconnected it and put it back in but it still does it. so someone help
Old Jul 18, 2004 | 11:33 AM
timmy8151's Avatar
Default Re: blinker problem (gsr-2nr)
Check your fuses.
Old Jul 18, 2004 | 11:38 AM
gsr-2nr's Avatar
Default Re: blinker problem (timmy8151)
i dont think it would b the fuses b/c all the others work xcept for the large bulb
Old Jul 18, 2004 | 12:36 PM
(theREAL)nightwalker's Avatar
check you blinker fluid, it could be low.
Old Jul 18, 2004 | 12:54 PM
timmy8151's Avatar
Default Re: blinker problem ((theREAL)nightwalker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by (theREAL)nightwalker &raquo;</TD></TR><TR><TD CLASS="quote">check you blinker fluid, it could be low.</TD></TR></TABLE>
HAHA.
Old Jul 18, 2004 | 01:48 PM
sabotage7's Avatar
maybe the socket is bad, a rock or something busted my turn signal housing and it was blinking fast and then not blinking at all....it also got moisture in there due to the humidity and weather and FL (which happened after like 20 mins).......so then i cleaned the contacts w/electrical cleaner and tried a new bulb and it worked for like a day and then quite working.......so i bought a socket from the dealer and replaced that and its perfect ever since!
Old Jul 18, 2004 | 02:48 PM
pearlteg's Avatar
Default Re: blinker problem (sabotage7)
check the wires maybe somewhere done the line there is a split where the wire are exposed and is causing a short therefore blowing the bulb
Old Jul 18, 2004 | 04:52 PM
gsr-2nr's Avatar
Default Re: blinker problem (pearlteg)
found the bastard the socket is bad. thanks 4 all ur help though
StreetRiot_DRE
Mar 4, 2008 07:16 PM
patrickstar
Jan 28, 2008 02:53 AM
CivicVelox17
Jan 2, 2007 10:11 PM
casmello
Aug 27, 2005 11:37 PM
gsr-2nr
Jul 18, 2004 04:53 PM
