car trouble
Old Jul 18, 2004 | 03:58 PM
mdj_ge's Avatar
Default car trouble
i have a 91 integra ls... when i start the car, the rpm keeps on jumping up and down... why is that, and how can i fix that...
Old Jul 18, 2004 | 04:54 PM
SmurfDA's Avatar
From: I live in a town with Boston traffic, mass, united states
Default Re: car trouble (yangja)
could be a vaccum leak, could be alot of things. how much do the rpms dance?
Old Jul 18, 2004 | 06:07 PM
mdj_ge's Avatar
Default Re: car trouble (93TealSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93TealSi &raquo;</TD></TR><TR><TD CLASS="quote">could be a vaccum leak, could be alot of things. how much do the rpms dance?</TD></TR></TABLE>
well, first when i start the engine, the Rpm goes really high at 3000 rpm and then after 10-20 sec, it starts dancing at 1000 - 2500 constanly... what could it be.
Old Jul 18, 2004 | 06:15 PM
SmurfDA's Avatar
could be very serious
Old Jul 18, 2004 | 07:28 PM
cyr0ch's Avatar
actually, most Honda's/Acura's are designed to do that when your coolant is low. Check your coolant. It's either low, or has an air bubble in it. If it is not low, have it flushed to get rid of any bubbles, which never hurts anyway. If that doesn't solve it, then it might be the Fast Idle Speed Valve. Most likely, it is your coolant system. I was informed of this from an Import Specialist when I couldnt figure out why my car was doing it.
Old Jul 18, 2004 | 08:31 PM
mdj_ge's Avatar
Default Re: car trouble (cyr0ch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyr0ch &raquo;</TD></TR><TR><TD CLASS="quote">actually, most Honda's/Acura's are designed to do that when your coolant is low. Check your coolant. It's either low, or has an air bubble in it. If it is not low, have it flushed to get rid of any bubbles, which never hurts anyway. If that doesn't solve it, then it might be the Fast Idle Speed Valve. Most likely, it is your coolant system. I was informed of this from an Import Specialist when I couldnt figure out why my car was doing it. </TD></TR></TABLE>
thanks so much... i'll try that...
one_fast_teg
May 31, 2011 05:52 AM
AFAccord
Oct 21, 2008 09:39 AM
tpatt
Apr 28, 2007 05:21 AM
hondateg10
Mar 5, 2007 06:08 PM
92HB_HB
Dec 7, 2006 02:50 AM
