Squeaking from the distributor...
Old Jul 19, 2004 | 12:48 PM
slickteg's Avatar
Default Squeaking from the distributor...
Alright guys and gals...I have this squeaking noise coming from my distributor. My guess is its not getting the oil from the engine that lubes the bearing in it. Does that sound like a correct diagnoses?? If so, would the fact that its missing the 2 bottom bolts that hold the distributor on cause this?? Thanks for the help...
Old Jul 19, 2004 | 12:52 PM
PlastikOwl
Guest
Posts: n/a
Default Re: Squeaking from the distributor... (slickteg)
if you're missing two bolts on your distributor, a squeaking noise should be the least of your worries.
It could be moving back and forth ******* up your timing.
Old Jul 19, 2004 | 05:59 PM
slickteg's Avatar
Default Bump...
Bump...
Old Jul 19, 2004 | 07:48 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Bump... (slickteg)
Umm.....so only one bolt is holding it in place? Get those other bolts in there like PlastikOwl, otherwise squeaking will be the least of your worries soon.
Squeaking, your distributor might be getting old, at least the parts. Check the condition of the cap and rotor. If those are good.....you might need a new entire unit.
Old Jul 20, 2004 | 04:37 AM
JimBlake's Avatar
Could be something rubbing down in the CYP & TDC sensors. Take the distributor off & spin the shaft to see if it turns nice & smooth. You'll have to figure out whether it's the rotor rubbing on the cap, or the sensors, or the bearing.
Old Jul 22, 2004 | 12:11 PM
slickteg's Avatar
Default Re: Squeaking from the distributor... (JimBlake)
Yeah the sealed bearing went bad...Thanks for the input...
kitt
May 1, 2010 02:26 PM
kenzo42
Feb 5, 2008 08:18 AM
Go_Kart_Driver
Apr 17, 2007 01:28 PM
B16CRXT
Feb 14, 2007 05:35 PM
khmboostedeh2
Jun 27, 2004 04:53 PM
