lsd ????
Old Mar 9, 2005 | 07:48 PM
tallguy's Avatar
Default lsd ????
I was looking through some past threads trying to find out some info on a good LSD for a good price. The only one that interested me was the obx unit, it sell for a good price and it has a life time warranty. the only problem is my friends car is an integra gsr, one of the posts said if you change the ring gear to a civic si ring gear the si unit will work.
Old Mar 9, 2005 | 07:50 PM
Haleiwa-Brando's Avatar
Default Re: lsd ???? (tallguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallguy &raquo;</TD></TR><TR><TD CLASS="quote">I was looking through some past threads trying to find out some info on a good LSD for a good price. The only one that interested me was the obx unit, it sell for a good price and it has a life time warranty. the only problem is my friends car is an integra gsr, one of the posts said if you change the ring gear to a civic si ring gear the si unit will work.</TD></TR></TABLE>
So whats your question(s)?
Old Mar 9, 2005 | 07:52 PM
aznsins88's Avatar
yea wat is your question?
Old Mar 9, 2005 | 08:05 PM
Kendall's Avatar
Why exactly would you change to an Si ring gear? It gives the exact same final drive ratio as the GSR ring gear.
tallguy's Avatar
Default Re: (aznsins88)
sorry if i change the ring gear will the civic one work.
Old Mar 9, 2005 | 08:28 PM
tallguy's Avatar
I know its late but is there anyone that can help.
Old Mar 9, 2005 | 09:35 PM
tallguy's Avatar
bump
Old Mar 10, 2005 | 05:52 AM
tallguy's Avatar
Default Re: (tallguy)
don't know... that's just what someone said. and exactly why im asking this question , to get more opions.
Old Mar 10, 2005 | 06:27 AM
IggyBcool's Avatar
why not go with the itr's helical lsd? or a quaife
Old Mar 10, 2005 | 06:37 AM
B16aef9's Avatar
If you have to yank the tranny and open it up I would not go with obx I would buy a quality LSD like a quaife.
Old Mar 10, 2005 | 07:20 AM
98lsskunk's Avatar
Default Re: lsd ???? (B16aef9)
kaaz makes good diffs. also
Old Mar 10, 2005 | 07:55 AM
95lstegman's Avatar
Default Re: lsd ???? (98lsskunk)
okay, to help this man out, here we go:
yes, the Civic SiR (for clarity, we'll call it SiR=B16A) has the same final drive as the GS-R.
no, the ring gears aren't the same. get one of each and try to put one on a B16 diff, then try the other. one will fit, the other won't.
now, first off, the GS-R unit from OBX is out, so you'd just get that one. second, yes you'd have to change the ring gear over to the SiR one. third, an OEM Type-R diff won't fit because you'd still have to change the ring gear. there, no more guessing.
Old Mar 10, 2005 | 08:18 AM
98lsskunk's Avatar
Default Re: lsd ???? (95lstegman)
ive heard about and have seen b16 diffs. break over 180 hp apps. they are not that strong so why not go with an aftermarket diff.
Old Mar 10, 2005 | 08:22 AM
Bay_707's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98lsskunk &raquo;</TD></TR><TR><TD CLASS="quote">ive heard about and have seen b16 diffs. break over 180 hp apps. they are not that strong so why not go with an aftermarket diff.</TD></TR></TABLE>
ctr lsd's breaking at 180hp? hah. Look at the people with built ctr motors using stock trannys.
Old Mar 10, 2005 | 08:30 AM
98lsskunk's Avatar
Default Re: lsd ???? (Bay_707)
no. b16a diffs. no one is talking about a b16b here
Old Mar 10, 2005 | 08:31 AM
IggyBcool's Avatar
whats the difference between the ctr and the itr tranny?
Old Mar 10, 2005 | 08:33 AM
98lsskunk's Avatar
Default Re: (99LStegra)
i know a itr tranny is double syncronized in every gear and a ctr is only in 3,4,5,
Old Mar 10, 2005 | 08:39 AM
95lstegman's Avatar
ctr tranny same 1-3 gears as JDM '98+ ITR, and shorter 4th and 5th gears. on the down side, like the ITR tranny, 4.785 final drive isn't standard. but if you get the 4.785 FD in a CTR tranny, congrats, you have the shortest gears possible, and a top speed of 137mph at 8500rpm in 5th gear. which also means you'll be doing 4656rpm cruising just at 75mph on the highway in 5th gear. not for daily driver, huh? race car stuff.
Old Mar 10, 2005 | 01:39 PM
tallguy's Avatar
thanx do know where i can find the obx gsr lsd.
Old Mar 10, 2005 | 07:05 PM
95lstegman's Avatar
ebay, baby. or just swap final drive to GS-R one. that's what i'm shooting for in my LS. slightly higher final drive won't hurt cruising volume too much or fuel economy (if i can stay off the right pedal).
JRCivic1
Transmission & Drivetrain
Jan 25, 2017 09:28 PM
noey
Honda Civic (2006 - 2015)
Jan 15, 2008 10:30 AM
cluelessmale
Dec 1, 2004 09:45 AM
turboex
May 11, 2004 05:31 PM
PainfulTeg
Mar 24, 2003 04:20 PM
