header Studs
Old Mar 7, 2005 | 06:09 AM
Liquidgsr's Avatar
Default header Studs
Two of the studs holding my header on to the head are broken. Left two. I am wondering should i replace these with stock studs or should i go for something stronger. ARP or something like that. Any suggestions?
Old Mar 7, 2005 | 07:06 AM
Tampa94lsteg's Avatar
Default Re: header Studs (Liquidgsr)
if they actually broke off in the head, your gonna have a hell of a time drilling the remaints out and putting in new ones unless the head is out of the car....I would just do stock honda....Now Head BOLTS, ARP...
Old Mar 7, 2005 | 07:18 AM
Honda Hick's Avatar
I would just get new Honda bolts and be sure to put Never-Seize on them when installing the nuts to ensure you can get them apart again.
I was lucky when I was taking out my broken stud. When I started drilling it the stud left in the head started turning. Then I just used an EZ-out to get it out. Hopefully you'll be that lucky.
Old Mar 7, 2005 | 07:51 AM
Liquidgsr's Avatar
Default Re: header Studs (Honda Hick)
yeah theres still enough left in there to take it out. I just need to get the tool to pull it out.
Old Mar 7, 2005 | 09:17 AM
gsrious's Avatar
i have enough left in the head to screw it out but for some reason can't because the broken stud in there is damn hard. should i just use more effort?
bow tie
Oct 21, 2008 12:03 PM
D16Y8-JDMYO
May 24, 2007 10:21 AM
civicb18Tkid
May 3, 2007 07:30 AM
civcexcoupeblack
Mar 23, 2003 01:22 PM
schwett
Apr 18, 2002 03:43 PM
