b16 on LS?
Old Mar 10, 2005 | 12:41 PM
redINTEGRAdriver's Avatar
Default b16 on LS?
i just have a quick question, will swapping a b16 tranny on a b18a raise the potential and power output of the motor ?
Old Mar 10, 2005 | 12:46 PM
LSvtec03's Avatar
Default Re: b16 on LS? (redINTEGRAdriver)
transmissions don't affect power, but it will help out your accelleration a ton.
Old Mar 10, 2005 | 01:03 PM
Default Re: b16 on LS? (LSvtec03)
will it cut time on the 1/4 ?
Old Mar 10, 2005 | 01:33 PM
3.504's Avatar
shorter gears will lower 1/4 times. the car will be considerably quicker.
the only problem with it is if you do alot of highway driving. the tranny will force the motor to be at higher rpm's during highway cruising speeds, which is not cool for an LS since its an unbalanced motor.
plenty of people have done the swap though. and i havn't heard of an LS coming apart because of it. but you never know.
Old Mar 10, 2005 | 01:36 PM
92 blue teg's Avatar
better accleration. got one if u need one. bought it and ended up not needing it. still in box. bought it for 550. and hundred shipping. just want money back. broke axle. didnt need trany. u can call at 757-477-4980 anytime.
Old Mar 10, 2005 | 01:47 PM
Default Re: b16 on LS? (heathb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">shorter gears will lower 1/4 times. the car will be considerably quicker.
plenty of people have done the swap though. and i havn't heard of an LS coming apart because of it. but you never know.</TD></TR></TABLE>
what do you mean its an unbalanced motor and around what RPM will it be at when cruising at around 65mph ?
Old Mar 10, 2005 | 02:14 PM
LSvtec03's Avatar
65 mph would be around 3500 rpm. i don't think the balancing of the motor would be a problem.
Old Mar 10, 2005 | 02:33 PM
3.504's Avatar
my S1 pulls 4000 at 65. but thats a crazier tranny than the y80's and other hydro clutch stuff. so i'd say 3500-upper 3000's. that is higher than the LS's.
shouldn't be a problem, just thought i'd throw in the info that cruising speed would be at higher r's. the LS is a balanced motor, just not as good of a balance as the vtec motors.
Old Mar 10, 2005 | 03:39 PM
LSvtec03's Avatar
Default Re: b16 on LS? (3.504)
speed/rpm calculator
specnically speaking: b-series gear ratio guide
all your questions are answered.
Modified by LSvtec03 at 9:08 PM 3/10/2005
Old Mar 10, 2005 | 03:56 PM
5litereater's Avatar
im running a 92-93 gsr tranny (ys1) on my b18a1 and it makes all the difference in the world. honestly, the higher rpm's on the highway are definately worth it. i recently bought a DA witht he stock ls tranny and it was soooo much slower.
i love my tranny.
Old Mar 10, 2005 | 05:44 PM
Brand's Avatar
im running a b16 tranny on my LS... accelaration had a noticeable improvement, but your car will be @ like 4100 rpms at 80mph
Old Mar 10, 2005 | 05:55 PM
Default Re: b16 on LS? (5litereater)
ok wait a minute... ever since i bought my DA last year, its always had a YS1 tranny. with a b18a1 block. so do you mean to tell me that my tranny is a gsr tranny? or is the ys1 on my car an LS tranny?
Old Mar 10, 2005 | 06:06 PM
LSvtec03's Avatar
there are 2 different ys1 trannies. (had you looked at the tranny guide link you would've figured it out )
one is the ls, which you almost certainly have. the other is the jdm rsi/xsi/ usdm 92-93 gsr. if you can cruise comfortably on the highway at 80, then you do not have the jdm ys1.
Old Mar 10, 2005 | 06:07 PM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redINTEGRAdriver &raquo;</TD></TR><TR><TD CLASS="quote">i just have a quick question</TD></TR></TABLE>
Me too. How come you have several different threads started about the same thing?
Old Mar 10, 2005 | 06:13 PM
Default Re: b16 on LS? (Haleiwa-Brando)
shhh....
dek1mfk
Jun 24, 2011 03:29 AM
tkhers2000
Feb 18, 2009 01:45 PM
bigslickek
22
Dec 6, 2007 11:04 AM
solk1dd
Jan 10, 2005 06:45 AM
W.O.P.
Nov 8, 2004 10:30 PM
