P420
Old Mar 10, 2005 | 01:23 AM
dayaftertomorrow's Avatar
Default P420
I live in Los Angeles. I got p420 on a 2001 gsr. OI cannot afford the Dealer cat. Should I buy one from Junk yard on line from another state(cuz cheaper) or I have to buy it in Calfornia because of the California smog check is different from other states. Thanks
Old Mar 10, 2005 | 05:38 AM
b62pteg#2's Avatar
Default Re: P420 (dayaftertomorrow)
By reading your post, I assume you are telling us your cat is bad, correct?
And since your car is an 01, the miles aren't too high, correct?
If so, the cat (at least the part cost) should be replaced free of charge I do believe, by Acura.
This is because all cats have to last a certain amount of time/miles. I think it's 80,000 miles, but I can't remeber.
Actually after a minute or two of searching, I found this:
All converters come with a federally mandated warranty. This warranty states that the converter shell and pipes are warranted for 5 years or 50,000 miles, whichever comes first, and that the catalytic converter was designed and manufactured to meet State and Federal emission reduction requirements, and when the vehicle's properly maintained, the catalytic converter is warranted to meet such requirements for 25,000 miles from the time of installation. Catalytic converters listed on this site have been tested according to the procedures in the Federal Register, Volume 51, No. 150, Tuesday August 5, 1986 and have met the performance criteria specified.
http://www.catalyticconverter.net/warranty.htm
That info was taken from that site.
But Acura might warranty them longer. Give Acura a call. Maybe your teg doesn't even have 50k miles on it, in which case you'de be OK
HTH
-- Kevin
Old Mar 10, 2005 | 05:56 PM
Default Re: P420 (b62pteg#2)
Thanks for your time. Mine is not 76,000 miles. Should I get a used one or buy a new one? Thanks
Jxi8s2k
Dec 2, 2007 02:34 AM
Imissvtec
Jun 12, 2007 07:10 PM
eurodeseo
Nov 13, 2004 10:49 AM
Tommy_Gunns
Jan 7, 2003 11:49 AM
BlueSi2k
May 7, 2002 09:55 AM
