B18a vs B18b...head difference?
Old Mar 8, 2005 | 04:12 AM
davens's Avatar
Default B18a vs B18b...head difference?
I've searched and all I found were tidbits and references to any differences.
I've got a stock B18b head/block right now.
I have the opportunity to buy a rebuilt B18a head with a port and polish job.
Aside from the valve covers, what are the differences in the head, if any?
Will my B18b Skunk2 manifold still bolt on?
I'm just rying to figure out if I should do it before I pay to have the new head shipped and find out it won't work (or has to be ghettorigge).
Thanks.
Old Mar 8, 2005 | 05:01 AM
NJIN BUILDR's Avatar
Default Re: B18a vs B18b...head difference? (davens)
All the parts will interchange.The "b" has slightly improved ports and cams.
Glenn
Old Mar 8, 2005 | 06:38 AM
95lstegman's Avatar
Default Re: B18a vs B18b...head difference? (NJIN BUILDR)
there are some minor differences in ports between the bare heads, but nothing to be discouraged about since it's ported. polishing isn't all it's cracked up to be, especially on street motors. PM to b!tch and moan about that statement. otherwise, the cams are smaller, the intake manifold runners are even less straight, the plenum is funny and smaller, and the throttle body is 58mm on b18a's where it's 60mm on b18b's. i think that about covers it.
Old Mar 10, 2005 | 12:45 AM
davens's Avatar
And a silly follow up question...are the valve covers interchangeable? I have the later "flat top" and prefer it to the earlier "bumpy top".
While its not a deal breaker...I'm just trying to weigh all the issues before deciding on the purchase.
Old Mar 10, 2005 | 05:17 AM
Default Re: (davens)
Valve covers will interchange between A and B.
Glenn
Old Mar 10, 2005 | 05:18 AM
95lstegman's Avatar
OBD-0 and OBD-1 valve covers easily interchange. OBD-2 valve cover does not [so] easily interchange with the other two. it has the PCV valve in the valve cover as opposed to on a can at the back of the block. you'll have to sort this out to use the late-model B18B and B20 valve cover.
Old Mar 10, 2005 | 07:58 AM
projectTeG's Avatar
i just say plug the obd2 valve cover hole and use the stock pcv port on the 18a's , or you could swap intake mani's
Old Mar 10, 2005 | 08:46 AM
95lstegman's Avatar
Default Re: (projectTeG)
swapping intake manifolds won't really help. i don't even use that little hole in mine. it's too much of a PITA to get the rubber hose in and out of it.
boostedb20z
Feb 20, 2008 06:09 PM
haggar
Aug 15, 2003 04:04 PM
redEFnine
Jul 9, 2003 10:35 PM
zCivic
Jul 1, 2003 06:21 PM
1991-DA
Jan 17, 2003 08:17 AM
