BOGGING PROBLEM PLEASE HELP!!!
Old Apr 3, 2005 | 04:46 PM
SOHCVTECx2's Avatar
Default BOGGING PROBLEM PLEASE HELP!!!
I swapped over a OBD1 b16a1 into my 96 GSR i am running my OBD2 ecu and it ran fine for about 3 months. Now its bogging from 1k-5k rpm anything after that is fine. I decided to try a OBD1 b16 ecu w/ the conversion harness to try it out, but the same result. I checked spark plugs, wires, and fuel injectors they are all good. Can someone help me troubleshoot this problem. thanks
Old May 18, 2005 | 12:30 PM
imprezzive's Avatar
Default Re: BOGGING PROBLEM PLEASE HELP!!! (SOHCVTECx2)
i got the same problem, i put obd1 b16 into my ls integra and it boggs like crazy when im tryin to get out of first gear and even second, but it doesnt stall. i just hit the gas and it goes i guess after all the gas is burned up inside the motor. can anyone help me out.
Old May 18, 2005 | 01:09 PM
hellasexyteg's Avatar
Have you checked your fuel pump
Old May 18, 2005 | 01:18 PM
92integraVTECgsr's Avatar
my 1992 gsr was doing the same..my friend advanced my timing by moving my distributor forward..worked like a charm..but dont move it too far..
Turboredteg
15
Oct 14, 2011 03:06 PM
powerpro_69
Sep 24, 2009 07:21 PM
y0o0orey
11
Aug 3, 2009 08:12 PM
xsi90teg
Feb 23, 2009 05:26 PM
H22civatch
Nov 4, 2005 06:50 PM
