suggestions on internal work
Old Apr 4, 2005 | 06:39 PM
GSRerrr's Avatar
Default suggestions on internal work
well im planning to run a stage 1 turbo maybe run it at low psi (7-9), but i wana make sure that nothin in the engine blows under the pressure. i know its ok to run on stock internals, but i jus wana be safe. But my main question is what all would i have to change internally? any help would be nice thanks in advance
--mike
Old Apr 4, 2005 | 06:48 PM
vtec_joe's Avatar
Default Re: suggestions on internal work (GSRerrr)
get low compression pistons, some eagle rods, arp studs and headbolts and all the other lil stuff for the block and ur good to go
Old Apr 4, 2005 | 06:58 PM
Ehop's Avatar
JE pistons 9.1:1 seem to b popular, eagle rods. from wut ive read thats good to around 10-12 psi. different head gasket and like vtec_joe said, studs n headbolts. u dont want compression to be too low cuz u wont make the HP. lower compression is for reliability not speed. higher compression will get u more HP but w/ higher compression u cant run as much boost
PrinceAli132's Avatar
You really don't have to get lower compression pistons, you can make better gains with higher compression pistons, or just stay stock and save your money for something else. Its all about how well you tune it. Look around in the Forced induction section and see what they say. Here are some good articles:
http://www.team-integra.net/fo...Topic
https://honda-tech.com/zerothread?id=830284
https://honda-tech.com/zerothread?id=964676
https://honda-tech.com/zerothread?id=664117
https://honda-tech.com/zerothread?id=516794
Hope this helps.
Ali
Old Apr 4, 2005 | 07:11 PM
GSRerrr's Avatar
Default Re: suggestions on internal work (PrinceAli132)
hey thanks alot guys, i really apreciate not geting flamed and getin actual help
thanks
o0o_tylor_o0o
Dec 7, 2010 07:03 PM
jmeyer99
Oct 24, 2010 10:32 AM
ljs88
Jul 15, 2007 01:14 PM
lavo81
May 8, 2005 03:48 PM
