tow hook help.
Old Apr 3, 2005 | 05:05 PM
nuWest's Avatar
Default tow hook help.
yes i searched.
yes i know this is pretty much useless.
no i didnt spend any money on this.
now that we got that out of the way....can anyone tell me/show me how to install one? i searched and went through about 3 pages and realized everyone and their mom wants a benen tow hook or that 90% of h-t thinks its useless.
thanks for the help.
Old Apr 3, 2005 | 06:24 PM
GreenTeaLS's Avatar
Default Re: tow hook help. (nuWest)
do you have the front or the rear? the rear tow hook bolts up to the stock tow hook location, its cake, the front requires some work. good luck
Old Apr 3, 2005 | 06:26 PM
nuWest's Avatar
front, at least i think it is, my friend gave it to me.
fck what all do i need to do for the front? anything have to be cut or modified? someone needs to do a write up maybe after im done with it ill post pics of everything, haha.
Old Apr 3, 2005 | 06:55 PM
GreenTeaLS's Avatar
Default Re: (nuWest)
Hey nuWest if you do it right, make a write-up with pics, i wanna see
Old Apr 3, 2005 | 07:00 PM
LSvtec03's Avatar
Default Re: tow hook help. (CypressGreenLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CypressGreenLS &raquo;</TD></TR><TR><TD CLASS="quote">do you have the front or the rear? the rear tow hook bolts up to the stock tow hook location, its cake, the front requires some work. good luck </TD></TR></TABLE>
i think you have it backwards. the rear one is welded in place, while the front ones are bolted on and can be removed and replaced.
Old Apr 4, 2005 | 05:56 AM
nuWest's Avatar
Default Re: tow hook help. (LSvtec03)
so where exactly do i bolt the front one onto?
Old Apr 4, 2005 | 06:32 AM
95lstegman's Avatar
there's a jack point forward and to the middle (left-to-right sense) of the car. it unbolts. it's just outside of the lower radiator support.
Old Apr 4, 2005 | 10:20 AM
nuWest's Avatar
Default Re: tow hook help. (95lstegman)
thanks, im in class right now, so ill check it out when i get home.
Old Apr 9, 2005 | 04:02 AM
Outkasted24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuWest &raquo;</TD></TR><TR><TD CLASS="quote">thanks, im in class right now, so ill check it out when i get home. </TD></TR></TABLE>
Did you decide to use it? Get it mounted?
If not.............I'll buy it from you!!!!!!!!!
What color is it?
Old Apr 9, 2005 | 04:27 AM
.water's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuWest &raquo;</TD></TR><TR><TD CLASS="quote"> 90% of h-t thinks its useless. </TD></TR></TABLE>
unless go track often. useless on the street
Ahkamow
70
Aug 3, 2012 01:10 PM
killercrx91
16
Jul 30, 2009 06:24 PM
mannydc5
Appearance Build Threads
Jul 2, 2008 04:54 PM
Stunna MIKE
14
Nov 20, 2005 08:10 PM
