Need Help on Wiring Reverse Lights
Old Apr 4, 2005 | 01:26 PM
MugenDC4's Avatar
Default Need Help on Wiring Reverse Lights
I've just recently did a auto > Manual conv. and needed some help on wiring the reverse lights. I've search around and many people said it was the Green and Yellow wire near the breather (The thin tube with the black cap) and wire it back to where the original auto shifter was. The problem is, i can't seem to find the green and yellow wire anywhere. I found 3 lose plugs two which is (Green/blue) and one is (Red/white) which i highly doubt because its near the starter.
Anyone help will be appreciated thx
Old Apr 4, 2005 | 03:06 PM
Irish Integra's Avatar
Default Re: Need Help on Wiring Reverse Lights (MugenDC4)
Thi wiring under the letter "A" in the first photo is your reverse light sender wiring from the 'box. Where is it going to? I would think that the plug marked A is probably the right one.
Just hook it up, slap her in reverse and see if there's light! If it works, well and good, if not you're on your own!
Good luck!
Old Apr 5, 2005 | 01:15 AM
MugenDC4's Avatar
Default Re: Need Help on Wiring Reverse Lights (Irish Integra)
thx for your help. Finally finish wiring up my reverse lights. BTW it wasn't the harness mark "A" it was the one next to it The guy who did my swap probably hook up the auto reverse harness to the manual reverse harness which confused me to find the reverse harness from the manual box
VTcivicHB
Acura TSX
Jul 15, 2011 09:59 PM
hitman123
13
May 1, 2009 03:57 PM
em1gangsta
Lighting
Jan 18, 2008 02:52 PM
MugenDC4
Apr 5, 2005 01:12 AM
coachkellum
Aug 30, 2004 03:31 PM
