Help Quick
Old Feb 7, 2006 | 04:37 AM
blkackteg's Avatar
Default teg distributor issue
Last night I replaced the cap and rotor on my distributor. It started right up, better than ever. This morning- not so much. Its cranking but not starting. Ive rechecked all of the connectionsand firing order is correct. Im at a loss. Anyone know what else I should check...
Modified by blkackteg at 5:57 AM 2/7/2006
Modified by blkackteg at 9:13 AM 2/7/2006
Modified by blkackteg at 9:29 AM 2/7/2006
Old Feb 7, 2006 | 12:33 PM
Sam92Teg's Avatar
Default Re: teg distributor issue (blkackteg)
Make sure your rotor screw didn't back out.
Does your CEL come on, then go out when you turn the key to start the engine? If it doesn't go back off, then your main fuel relay isn't allowing the pump to pressurize the system, at least that is how it works on my 92 RS. MFR is a common problem with our tegs.
Could also be coil, ignitor problem, and you can have them tested. Pull a plug wire off and stick an old spark plug in the pulled wire boot and have someone crank the engine, in other words, test for spark to see if you have it.
platinum_rich
15
Feb 25, 2012 08:16 PM
yzhang
Jun 21, 2009 11:13 AM
97honda civic dx
18
Apr 12, 2009 06:41 AM
matt69vdub
Jul 23, 2007 08:35 AM
crxY-49
Sep 10, 2003 12:23 PM
