Competion Clutch Problem
Old Feb 6, 2006 | 10:59 AM
VTECgsr00's Avatar
Default Competion Clutch Problem
I just installed a competition clutch gravity clutch stage 1. Now i hear a whistling noise when clutch disengaged and when i step on clutch pedal it goes away. Also I am getting tons of clutch chatter. Is that normal for this clutch? Please help.
Old Feb 6, 2006 | 12:38 PM
iHOPEyouCHOKE's Avatar
* B A N N E D *
Default Re: Competion Clutch Problem (VTECgsr00)
throwout bearing.
i have one for sale brand new if you need one.
i had to replace my throwout bearing in my spec clutch because it did the same thing.
Old Feb 6, 2006 | 06:38 PM
VTECgsr00's Avatar
Default Re: Competion Clutch Problem (iHOPEyouCHOKE)
Is the throwout bearing just causing the noise? or is it making it chatter too?
Old Feb 6, 2006 | 06:43 PM
rob d's Avatar
i had the same problem with that same clutch kit. then i bought an oem bearing and it went away
Old Feb 7, 2006 | 07:39 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECgsr00 &raquo;</TD></TR><TR><TD CLASS="quote">Is the throwout bearing just causing the noise? or is it making it chatter too?</TD></TR></TABLE>
new clutches tend to chatter until fully broken in.. but if it sounds like a whiny noise, it's your throwout bearing. after installing my spec stage 2 i got chatter and the whining.. after awhile, the chatter went away.
if you need a new T/B i have one brand new that i've been wanting to get rid of.
Old Feb 7, 2006 | 09:08 AM
VTECgsr00's Avatar
Is it bad to drive with the throwout bearing do that? like will it screw something else up. My problem is that I didnt install the clutch, I brought it to a shop and im afrai they will tell m e that i have to pay nother 2-300 dollars to fix it.
Old Feb 7, 2006 | 09:30 AM
* B A N N E D *
honestly not too sure.
why not fix it before it could cause something worse?
Solstic
Jun 13, 2012 11:34 AM
petty$rep
Oct 31, 2006 08:45 PM
FkingSUV
Apr 15, 2005 01:25 PM
integra_si-vtec
Nov 13, 2004 08:14 PM
viperguy
Aug 14, 2003 11:59 AM
