obd2a-obd-1 conversion ?
Old Feb 6, 2006 | 06:31 PM
93slmdcvcsi's Avatar
Default obd2a-obd-1 conversion ?
when converting a obd2a-obd1 what all has to be done other than buy a ecu jumper? do i need to use a obd 1 dizzy or can i use the obd2 one, and i know that the crank sensor is on the oil pump on a obd2, but do i hav to run the crank sensor wires to the obd 1 dizzy?
Old Feb 6, 2006 | 06:41 PM
mattcivic's Avatar
Default Re: obd2a-obd-1 conversion ? (93slmdcvcsi)
i just put my jumper in and it works just fine.
Old Feb 6, 2006 | 06:43 PM
Kowalski's Avatar
Mine was plug and play.
Old Feb 6, 2006 | 06:48 PM
Default Re: obd2a-obd-1 conversion ? (mattcivic)
well what i am getting at is, a friend of mine has a 98 integra GSR with a 1993 B17 swap in it and it dont hav a crank sensor on the oil pump. i am trying to find out if i am gonna hav too put a crank sensor on it!
Old Feb 6, 2006 | 06:49 PM
mattcivic's Avatar
if u get a jumper and make it obd-1 u wont need one.
Old Feb 6, 2006 | 07:07 PM
where will it get crank position from then? the dizzy?
Old Feb 6, 2006 | 07:54 PM
bump
Old Feb 6, 2006 | 07:55 PM
Novtecdohc's Avatar
The CKS on obd1 is intergrated into the distributor... On Obd2 cars, its on the oil pump... if you conveting to obd1 you can still use you obd2 distributor but you will give a CEL for the CKS... But your car will run fine..... (atleast mine gave a CEL)
no2unenolife's Avatar
plug and play for me
Old Feb 6, 2006 | 08:45 PM
mattcivic's Avatar
Default Re: (no2unenolife)
ya ive never gotton a CEL fromt he crank sensor. ive got a skunk2 harness maybe yours is jsut different??
akinas-crx
Oct 28, 2011 06:00 PM
EKB18BPR3
Mar 13, 2005 07:22 PM
aw1234dude
Dec 15, 2004 06:32 PM
aw1234dude
Dec 7, 2004 01:27 AM
aw1234dude
Dec 7, 2004 12:56 AM
