help!!!
Old Feb 4, 2006 | 07:21 PM
iheartmyej8's Avatar
Default help!!!
i have a 90 integra LS. I relocated my battery to the back on tues. fri i go and help one of my buddies jump off his car. now mine is f-d up. i just put a new battery and starter in today. i thought it was my starter because iam getin juice to starter but not enough to turn it. but i just put my battery back in the factory position under the hood, now it starts but lights and everything is actin like it has not enough power. so is somthin hooked up wrong or does it sound like my alternator?
Old Feb 5, 2006 | 07:33 AM
Default Re: help!!! (iheartmyeg)
somebody help please
Old Feb 5, 2006 | 07:41 AM
blkb18's Avatar
check your grounds
Old Feb 5, 2006 | 07:54 AM
jmcool's Avatar
Default Re: help!!! (blkb18)
i agree probably just lose or bad ground
Old Feb 5, 2006 | 08:09 AM
Default Re: help!!! (jmcool)
where at?
Old Feb 5, 2006 | 10:25 AM
thanks guys. i put another ground and now works. thanks.
Old Feb 5, 2006 | 01:01 PM
Gojira D.O.T's Avatar
its easy to check your alt if u get it running just disconnect the batt after its started and it should stay runningif not the alt is bad
Old Feb 5, 2006 | 03:10 PM
DirtyBirdJR's Avatar
Default Re: help!!! (Gojira D.O.T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gojira D.O.T &raquo;</TD></TR><TR><TD CLASS="quote">its easy to check your alt if u get it running just disconnect the batt after its started and it should stay runningif not the alt is bad</TD></TR></TABLE>
you are a moron
dudee
Nov 23, 2010 07:34 AM
Integ808
Oct 16, 2008 02:57 AM
kona_4door
Dec 5, 2006 06:30 PM
jamie9500
Jul 3, 2006 03:59 PM
tigueremalo
May 23, 2006 10:55 AM
