What is the difference from a dc2 and dc4?
Old Jan 10, 2007 | 12:55 AM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Default What is the difference from a dc2 and dc4?
I just had to ask.
Old Jan 10, 2007 | 01:01 AM
nate_2k5's Avatar
Default Re: What is the difference from a dc2 and dc4? (Dynasty21)
dc2 = type r and gs-r, everything else is a dc4
Old Jan 10, 2007 | 01:03 AM
Dynasty21's Avatar
Default Re: What is the difference from a dc2 and dc4? (nate_2k5)
What does the type r and gsr have in common?
Old Jan 10, 2007 | 01:36 AM
Hondaholik's Avatar
.........VTEC.........
Old Jan 10, 2007 | 01:44 AM
Dynasty21's Avatar
Default Re: What is the difference from a dc2 and dc4? (Hondaholik)
besides that? just cuz its vtec they decide to have a whole "new" chasis name?!
Old Jan 10, 2007 | 01:50 AM
god.loves.ugly
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dynasty21 &raquo;</TD></TR><TR><TD CLASS="quote">besides that? just cuz its vtec they decide to have a whole "new" chasis name?!</TD></TR></TABLE>
yes.
Old Jan 10, 2007 | 01:54 AM
Dee's Avatar
Dee
You have got to be kidding
The different body codes correspond with a specific engine code.
Now, go do a seach!!
Old Jan 10, 2007 | 11:07 AM
Nataku's Avatar
Default Re: What is the difference from a dc2 and dc4? (Dee)
The TYPE-R and GSR have completely different frame structures. The ITR is more ridged
Old Jan 10, 2007 | 11:18 AM
BlueIntegraBoy's Avatar
Default Re: What is the difference from a dc2 and dc4? (Nataku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku &raquo;</TD></TR><TR><TD CLASS="quote">The TYPE-R and GSR have completely different frame structures. The ITR is more ridged</TD></TR></TABLE>
Not that different, just welded better.
SimplyB18C1's Avatar
GSR = B18C1 Engine Code (Rated at 170 hp / at the crank)
Type- R = B18C5 Engine Code (Rated at 195 hp / at the crank)
Type-R is more rigid and less chassis flex because it has an additional rear strut bar and the engine compression is higher NA than a GSR. So the Type-R has a little better internals and a bigger throttle body for more air, a little bigger bore size, intake manifold, exhaust manifold. The additional horsepower from the B18C5 is just some things that Honda improved over the existing B18C1 to make it a high compression NA motor that doesn't really need to be upgraded much because It comes out really well straight out of the factory. The Type-R also has a 5 lug nut design compared to only 4 on the GSR (only 97 Type-R model had 4 lugs) The Type- R also came in limited production and limited paint color codes. Phoenix Yellow, NightHawk Black Pearl, Championship White. Type- R also has Recaro seats in the front (black with red stitching). Also the shift boot, steering wheel,**** is the signature black with red stitching look. Hope that helped a little.
Old Jan 10, 2007 | 11:28 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (SimplyB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimplyB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">GSR = B18C1 Engine Code (Rated at 170 hp / at the crank)
Type-R is more rigid and less chassis flex because it has an additional rear strut bar and the engine compression is higher NA than a GSR. So the Type-R has a little better internals and a bigger throttle body for more air, a little bigger bore size, intake manifold, exhaust manifold. The additional horsepower from the B18C5 is just some things that Honda improved over the existing B18C1 to make it a high compression NA motor that doesn't really need to be upgraded much because It comes out really well straight out of the factory. The Type-R also has a 5 lug nut design compared to only 4 on the GSR (only 97 Type-R model had 4 lugs) The Type- R also came in limited production and limited paint color codes. Phoenix Yellow, NightHawk Black Pearl, Championship White. Type- R also has Recaro seats in the front (black with red stitching). Also the shift boot, steering wheel,**** is the signature black with red stitching look. Hope that helped a little. </TD></TR></TABLE>
correction: JDM 1996 ITR had 4 lugs, all USDM ITR's and 97-up JDM ITR's had 5-lug.
Yeah people have often wondered why the GS-R and ITR have the same chassis code, when in fact their chassis are quite different. Whereas the RS/LS/GS has the exact same chassis as the GS-R (just different engine) and yet it is called DC4 instead of DC2.
And then even more odd is the fact that the 4th gen Integra/RSX is still called a DC chassis, but just with a different number (DC5). That makes no sense at all.
Old Jan 10, 2007 | 11:55 AM
doood's Avatar
been there done that
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
And then even more odd is the fact that the 4th gen Integra/RSX is still called a DC chassis, but just with a different number (DC5). That makes no sense at all.</TD></TR></TABLE>
yay honda for confusing the hell out of people
Old Jan 10, 2007 | 12:36 PM
Nataku's Avatar
Default Re: What is the difference from a dc2 and dc4? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
Not that different, just welded better.</TD></TR></TABLE>
No, Not just welds... Look at diagram below.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Type-R is more rigid and less chassis flex because it has an additional rear strut bar</TD></TR></TABLE>
More than just a rear strut bar. Also Look Below.
Old Jan 10, 2007 | 12:54 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku &raquo;</TD></TR><TR><TD CLASS="quote">No, Not just welds... Look at diagram below.</TD></TR></TABLE>
True, not just welds, but also not a "completely different frame structure". Also note that the GS-R'S chassis is no different than other Integra models -- only the ITR is unique.
Old Jan 10, 2007 | 01:03 PM
KBG Indey's Avatar
although the gsr does come with better suspension from the factory.
Old Jan 10, 2007 | 01:36 PM
Padawan's Avatar
Darth ModerVader
Default Re: (IndeyAttack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndeyAttack &raquo;</TD></TR><TR><TD CLASS="quote">although the gsr does come with better suspension from the factory.</TD></TR></TABLE>
If by better suspension you mean different sway bars, then yes.
Old Jan 10, 2007 | 02:05 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimplyB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">So the Type-R has a little bigger bore size, </TD></TR></TABLE>
Im sorry, BAHWHWHA nothing i read that you type i will ever take as being credible information again!!
Old Jan 10, 2007 | 04:39 PM
KBG Indey's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
If by better suspension you mean different sway bars, then yes. </TD></TR></TABLE>
and strut bar
1998b18c1
Apr 7, 2007 05:13 PM
BG-Teg
Feb 13, 2007 10:15 AM
southcoast integra
Oct 24, 2006 10:08 AM
jDm_jeremy
Nov 16, 2003 09:02 AM
daniel_au
Apr 16, 2003 10:13 AM
