Launching?
Old Jan 10, 2007 | 09:34 PM
team 15's Avatar
Default Launching?
i have a question when launching my integra gsr. Do you have to step on the gas hard after you let go of the clutch or maintain the gas at haft throttle? I launch at 3000 rpm.
Old Jan 11, 2007 | 06:03 AM
501hpintegra's Avatar
Default Re: Launching? (team 15)
That is considered half throttle shifting, and you can do that you will just go thru clutches like crazy and depending on tracktion hp and axel type you snap somethin.
I use hondata and they have a option called full trottle shifting foot to the floor and don't let up when shifting and the rpms are set at a specific range may want to look inot that.
Either that good luck and Be care not to break anything
Old Jan 11, 2007 | 10:04 AM
95 integra's Avatar
Default Re: Launching? (501hpintegra)
Generally you launch it around 3k, start to slip the clutch and add throttle enough so that the motor doesnt bog or bounce to redline previous to the clutch being full out. Generally, its a smooth action of letting the clutch out (start out slow and then get faster) and slowly rolling on the throttle until you reach 100% throttle. Clutch "dumps" are not a good way to launch, so just practice the slipping idea.
Old Jan 11, 2007 | 10:32 AM
Boots's Avatar
Default Re: Launching? (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Generally you launch it around 3k, start to slip the clutch and add throttle enough so that the motor doesnt bog or bounce to redline previous to the clutch being full out. Generally, its a smooth action of letting the clutch out (start out slow and then get faster) and slowly rolling on the throttle until you reach 100% throttle. Clutch "dumps" are not a good way to launch, so just practice the slipping idea.</TD></TR></TABLE>
i have not seen a bad peice of advice come from this man
Old Jan 12, 2007 | 11:47 AM
Default Re: Launching? (boots)
Well said I should have read better he was talking about launching and you hit it right on the dot . Good man 95 Integra
Legendary Valky
Mar 5, 2016 01:28 AM
Accord2k-Hybrid
Jul 16, 2006 06:46 PM
Panoply
May 26, 2006 11:40 AM
Mai_CL-S
Mar 2, 2002 03:16 PM
BoM
Jun 21, 2001 06:44 PM
