high compression ls/vtec?
Old Jan 9, 2007 | 12:40 PM
92integra-R's Avatar
Default high compression ls/vtec?
im building a ls/vtec, a b18a1 block and oem crank. i got a set of eagle h-beam rods from a buddy of mine. they came outta if his ls/vtec. i want to use those rods and some new pistons. i dont plan on sleeving the a1. i was wanting to use some p73 pistons (JDM type-r). someone told me i would have to do something to the pistons to work. is this true?
Old Jan 9, 2007 | 12:44 PM
doood's Avatar
been there done that
Default Re: high compression ls/vtec? (92integra-R)
you need to modify them to accept floating wrist pins with retainer clips. stock uses press fit pins.
Old Jan 9, 2007 | 12:47 PM
Default Re: high compression ls/vtec? (doood)
who can do this? im tring not to spend alot in this build. should i just buy different pistons?
Old Jan 9, 2007 | 01:25 PM
DC2 Mang's Avatar
to save time either buy forged pistons to onto the h-beams, or sell the h-beams and buy some OEM LS rods to press the ITR pistons onto
Old Jan 9, 2007 | 01:27 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra-R &raquo;</TD></TR><TR><TD CLASS="quote">who can do this? im tring not to spend alot in this build. should i just buy different pistons?</TD></TR></TABLE>
any competent machine shop should be able to do this. but...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">to save time either buy forged rods to out onto the h-beams, or sell the h-beams and buy some OEM LS rods to press the ITR pistons onto</TD></TR></TABLE>
werd
Old Jan 9, 2007 | 05:04 PM
Default Re: high compression ls/vtec? (DC2 Mang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">to save time either buy forged pistons to onto the h-beams, or sell the h-beams and buy some OEM LS rods to press the ITR pistons onto</TD></TR></TABLE>
i got the stock LS rods, but i think id rather just go with new pistons. any suggestions on a aftermarket piston? oh yeah, i got s2 springs and retainers in the b16 head i plan on using. will the stock valves hold up in this setup?
Old Jan 9, 2007 | 05:18 PM
DC2 Mang's Avatar
the stock valves will hold up
good aftermarket pistons about be CP, JE, Wieseco, and arias
Old Jan 10, 2007 | 11:31 AM
doood's Avatar
with forged pistons and stock rods, you then have to modify the pistons to accept a press fit pin. either upgrade both or dont upgrade at all.
Old Jan 10, 2007 | 08:47 PM
silentdeath12886's Avatar
i was told before forged pistons and stock sleeves dont work very well together because of the different or same metals rubbing against each other and were recommended that if someone were to get forged pistons that they should sleeve the block as well. correct me if im wrong?
Old Jan 10, 2007 | 09:01 PM
viet_boi_racin's Avatar
Default Re: (silentdeath12886)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdeath12886 &raquo;</TD></TR><TR><TD CLASS="quote">i was told before forged pistons and stock sleeves dont work very well together because of the different or same metals rubbing against each other and were recommended that if someone were to get forged pistons that they should sleeve the block as well. correct me if im wrong?</TD></TR></TABLE>
Forged piston is fine with OEM sleeves. Plenty of people making 400+whp on stock sleeves.
I'd just get some forged piston if i were you since you already have forged rods. But if you want to use CTR pistons. You're going to have to take the rods and pistons to a machine shop and get some machine work done.
Old Jan 11, 2007 | 09:16 AM
flamega's Avatar
Default Re: (viet_boi_racin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viet_boi_racin &raquo;</TD></TR><TR><TD CLASS="quote">
I'd just get some forged piston if i were you since you already have forged rods. But if you want to use CTR pistons.</TD></TR></TABLE>
i just wanted to chirp in here real quick...i've been reading up on my stuff, and want to see if i remember correctly.
i've been hearing that CTR pistons are NOT really that reliable/good. is this true?
Old Jan 11, 2007 | 11:25 AM
Sam92Teg's Avatar
Default Re: (flamega)
They seem to do well in the Civic Type R.
You have to match the piston to the application. If your building an LSVTEC and want to be streetable, the compression numbers with the CTR pistons might not be what you want, maybe P30's would be a better choice.
Old Jan 11, 2007 | 11:29 AM
doood's Avatar
Default Re: (Sam92Teg)
that only applies to the h22
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flamega &raquo;</TD></TR><TR><TD CLASS="quote">i just wanted to chirp in here real quick...i've been reading up on my stuff, and want to see if i remember correctly.
i've been hearing that CTR pistons are NOT really that reliable/good. is this true?</TD></TR></TABLE>
ctr's are heavy and have a huge dome giving you a really high cr for a street application. you can get around it but why not go with less compression from p30's or p73's and make more power?
Old Jan 11, 2007 | 11:55 AM
jdm_bones's Avatar
bro, just get P30 pistons...and you wont have to go throw all that jazz!
Old Jan 11, 2007 | 03:17 PM
Default Re: high compression ls/vtec? (jdm_bones)
i got low comp wisecos in my c5, with eagle rods. i like how i was able to put them together myself. i'll probably get some high comp wisecos for the ls/vtec. recommend a compression?
Old Jan 16, 2007 | 08:35 AM
flamega's Avatar
correct me if i'm wrong...isn't a 'high compression', NOT what you want...? especially with turbo applications?
the lower compression you have, the more 'boost' you can fit...right? and isn't more boost better?
i know these are rookie questions, but i'm learning.
Old Jan 16, 2007 | 08:51 AM
lVlemphizStylez's Avatar
Default Re: high compression ls/vtec? (flamega)
Where did the OP mention anything about boost??? The title of thread was High Compression LS/VTEC
Old Jan 16, 2007 | 09:27 AM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra-R &raquo;</TD></TR><TR><TD CLASS="quote"> recommend a compression?</TD></TR></TABLE>
11.5:1 to 12:1 on 91 octane for the highest performance, daily driveability and reliability combonation
Old Jan 16, 2007 | 10:39 AM
12:1 on 91 octane??? = /...pushing the limits huh??
Old Jan 16, 2007 | 10:43 AM
DC2 Mang's Avatar
Default Re: high compression ls/vtec? (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">12:1 on 91 octane??? = /...pushing the limits huh??</TD></TR></TABLE>
not by much, my 12:1 LSvtec ran fine on 91 octane without a tune on a stock GSR map at factory timing spec before I got it tuned
best thing to do is to get it to a tuner as soon as possible they may need to retard the timing a little bit but not too much
Old Jan 17, 2007 | 07:31 AM
flamega's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">Where did the OP mention anything about boost??? The title of thread was High Compression LS/VTEC</TD></TR></TABLE>
i'm sorry. i must not know what LS/VTEC stands for then. i just assumed that there was a turbo present in the discussion.
so then...if there is no turbo present, then high compression is a good thing?
once again, i'm sorry for the novice questions. i'm not trying to waste anyones time.
Old Jan 17, 2007 | 07:42 AM
If you're trying to make power all motor, then yea high compression is a good thing..LS-VTEC can be a boosted or all motor application, it's just utilizing the r/s ratio of the ls bottom end with a free flowing VTEC head
Old Jan 17, 2007 | 01:52 PM
flamega's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">If you're trying to make power all motor, then yea high compression is a good thing..LS-VTEC can be a boosted or all motor application, it's just utilizing the r/s ratio of the ls bottom end with a free flowing VTEC head</TD></TR></TABLE>
good...what i just went and learned, matches with what you just said perfectly!
i'm gonna go learn about some more tuning now.
ys1civicsi
Feb 4, 2008 06:44 AM
queda
12
Nov 1, 2007 10:05 PM
the.hamburglar
Dec 28, 2005 03:46 PM
spoonzdelsol
12
Aug 7, 2005 08:13 PM
Wazup
May 7, 2003 08:26 AM
