B18B1 replacement
Old Jan 10, 2007 | 09:36 PM
vitzteg's Avatar
Default B18B1 replacement
I'm in the middle of replacing the B18B1 in my '96 teg with a B18B1 from a '95 (easier than replacing the crank that some a-hole had crossthreaded when they had done the timing belt). And if you're curious - I didn't feel like rebuilding, besides; if I do rebuild, I'll be getting some aftermarket slugs, rods, crank, etc which is way more than $800 for a JDM motor. The goal will be putting a turbo later down the road...
Anyway, I was wondering what's the minimum needed to fire up the motor? I was going to see if I could just bolt the motor/tranny in and just hook up water. fuel, and 12v. Honda motors are new to me (this is my first) - I'm a small block chevy guy - but I can't beat the teg for the daily driver with 30 mpg. On the chevy, I could just get the block in, hook up gas and the battery and fire it up briefly before bolting everything else in (and then tune it after it's all put together). Just wasn't sure if I could do that with the Honda motor or not because of all the sensors, etc. Besides, there's a ton more stuff to put back together on the teg than the chevy
Thoughts? Thanks
Old Jan 10, 2007 | 09:52 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: B18B1 replacement (vitzteg)
connect it all.
Old Jan 16, 2007 | 09:25 PM
vitzteg's Avatar
connected it all - fired up the first try! In fact, the maint light goes away too... how cool is that?!
Old Jan 17, 2007 | 06:49 AM
MINTGRN4DR's Avatar
the maint light is a mileage thing it trip every so many mile and there is a reset button under the dash
the c.e.l. is different of course
Old Jan 17, 2007 | 07:22 AM
fyqprmdobe's Avatar
Default Re: (MINTGRN4DR)
he meant the cel you nub
WASLS1NOWHONDA
Apr 14, 2010 06:29 AM
Mak1e-Tee
Mar 31, 2008 03:47 PM
nota-eg
Jun 15, 2006 10:26 AM
monalisa overdrive
Oct 20, 2004 10:54 AM
Nextelbuddy
Feb 15, 2004 09:43 PM
