cel light on..
Old Jan 13, 2007 | 01:01 PM
MATiC's Avatar
Default cel light on..
i have a 00 integra ls.
check engine light is on right from the get-go.
put key in ignition, turn it to where u can start messing with the power windows and such, and cel light clicks on.
stays on after i turn on car..
dont have a code reader, but n e suggestions..?
Old Jan 13, 2007 | 01:26 PM
MATiC's Avatar
Default Re: cel light on.. (MATiC)
well, i tried to pull the codes using the obd1 method, using a paper clip with the connector..
and i got code 3..
MAP - manifold absolute pressure sensor
Old Jan 13, 2007 | 01:59 PM
Dogginator's Avatar
Daisy... Daisy...
From the FAQ:
https://honda-tech.com/zerothread?id=978933
OBDII codes are read the same. If you want more specific information on the MAP code (03), go to your local parts store. They should read the codes for free.
Old Jan 13, 2007 | 02:33 PM
MATiC's Avatar
would it be safe to say, in any event, i'm gonna hafta replace the map sensor?
Old Jan 13, 2007 | 03:22 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (MATiC)
Most likely, yes. I would check the connections first.
Old Jan 13, 2007 | 03:58 PM
MATiC's Avatar
yeah, i checked all connections.
also sprayed the plugs with some electronic parts cleaner.
no go..still have the CEL light on throwing same code.
*sigh* i guess i'll have to order one. and guess what?! no fn auto parts store here as one. sonofa..
Old Jan 13, 2007 | 04:14 PM
Brick Top's Avatar
Default Re: (MATiC)
MAP is a real expensive sensor from the dealer. FYI
Old Jan 14, 2007 | 10:13 PM
ckyfan87's Avatar
Default Re: (brick top)
EBAY!!!!
Old Jan 14, 2007 | 10:19 PM
numbnuts22715's Avatar
I would definately go to autozone or o'reillys or wahtever and get it scanned before you make any repairs.
9tailsfox
14
Feb 20, 2012 07:44 AM
EJ6er
Jun 30, 2011 08:50 PM
fsg231
May 15, 2010 04:32 PM
JDM-EJ1
Apr 5, 2005 11:55 AM
2DXtreme
Apr 1, 2005 11:00 AM
