90 DA with idle problem
Old Jan 13, 2007 | 09:38 PM
90datech's Avatar
Default 90 DA with idle problem
ok i started to get a code 8. Thats for the dizzy right. then my main relay stoped working. so i repalced the relay and adjusted the valves cause they were real loud. i set the intake to .005 and the exhaust to .008, i dont know if this is the right setting for a 95 ls head. but now when i start the car up the idel doesn't bounce anymore, instead it goes straight to 3k rpm and stays. anybody know what is wrong?
Old Jan 14, 2007 | 12:56 AM
Mattyg2's Avatar
FITV and IACV, adjust the fitv valve and clean out the iacv if that doesn't work, then im not sure
Old Jan 14, 2007 | 05:08 PM
BacardiBreezer's Avatar
Default Re: 90 DA with idle problem (moreteck)
THat's what I was going to suggest, here are some links:
http://g2ic.com/forums/showthr...=fitv
Old Jan 15, 2007 | 12:32 PM
90datech's Avatar
Default Re: 90 DA with idle problem (BacardiBreezer)
thanks, but all of that is new,
so im gona wait and see when i get my new dissy if it fixes it.
Old Jan 15, 2007 | 02:05 PM
Mattyg2's Avatar
most likely its the FITV and IACV, i just fixed mine today and that was the problem. now my idle is perfect...for now
Old Jan 15, 2007 | 06:55 PM
emissionsux's Avatar
Well did you fix the code 8 problem? You really need to address that before anything since that is your TDC sensor. It can actually that your timing is way off causing the idle to raise like that. Check your timing marks to see if everything lines up. If they do, your distributor might be going.
Old Jan 15, 2007 | 07:00 PM
90datech's Avatar
Default Re: 90 DA with idle problem (emissionsux)
yeah i got a new dizzy,just waitin for it to get here so i can fix the code 8.
today i went outside and started it and the idel started to bounce again. so im hopin the dizzy is the problem.
Old Jan 26, 2007 | 08:33 PM
Mattyg2's Avatar
its not the "dizzy" most likely its the FITV, this is common for the 90-93 integra now since the car is like 15 years old. all you have to do is screw in the white thing and clean the iacv out with some simple green or something and the idle should return back to normal, at least mine did and my friends integra have
crxguy406
Sep 10, 2015 03:56 AM
b18b1ef8
Mar 27, 2009 07:02 AM
samdizzle562
May 30, 2007 12:21 PM
^MikeG
Jul 13, 2005 11:33 AM
Juccord
Jun 3, 2004 12:17 PM
