need help!!!
Old Jul 13, 2007 | 10:21 PM
slimteg101's Avatar
Default need help!!!
well i thought my starter was bad so i took it to get it test and everything passed so after putting it back in i decided i would try it again and still doesn't work, and have no clue what it could be.....so i was talking with a friend thats a mechanic and he said that maybe the teeth on the flywheel are bad.....so i put my finger down where the starter goes in and connects with the flywheel and it feels like the teeth are all there, so i was wondering what else it could be?!?!?!?!?!?.........please help i did sum searching and really couldn't find anything
Old Jul 14, 2007 | 05:57 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: need help!!! (slimteg101)
What are your symptoms? Does the starter even spin when the key is turned?
Old Jul 14, 2007 | 06:02 AM
slimteg101's Avatar
Default Re: need help!!! (Dogginator)
yeah it does spin or at least sounds like it spins freely then it sounds like it grinds after awhile
Old Jul 14, 2007 | 06:16 AM
Dogginator's Avatar
Daisy... Daisy...
The solenoid sounds like it is not functioning properly to engage the starter gear with the flywheel.
Old Jul 14, 2007 | 11:50 AM
MatterMatt's Avatar
YOU ARE CORRECT! A starter might seem like its working but won't start a car because the little gear doesn't stick out far enough to catch the flywheel. I put a starter in a"03 CR-V the other day because the solenoid would only push the gear out far enough to catch the flywheel intermittently. Otherwise it would only spin or grind. Pony up some rubles for a starter!
Old Jul 14, 2007 | 05:54 PM
slimteg101's Avatar
Default Re: need help!!! (MatterMatt)
so i would have to buy a new starter still?...or could it possibly be solved by replacing the contact points?
Old Jul 14, 2007 | 06:59 PM
MatterMatt's Avatar
New starter. Period.
DarkBB4
Apr 25, 2005 01:08 PM
MikekiM
Jan 18, 2005 09:47 AM
typeRicer hater
Jan 9, 2003 12:56 AM
SpoolnG2
Dec 27, 2002 10:27 AM
non-VTEC
Apr 29, 2002 10:43 PM
