please help
Old Jul 12, 2007 | 03:25 PM
95GSRDC2's Avatar
Default please help
hey guys my car is not running right,its a 95 integra gsr, when im in second or first or any gear and i floor it it feels like im in 5th going 20, it has like no power,i changed the fuel filter, fuel pump, fuel injectors, fuel pressure regulator i cant figure it out. please help me!!!!!!!
Old Jul 12, 2007 | 03:31 PM
posHonda's Avatar
fusl pressure regulator??
what mods do you have?
Old Jul 12, 2007 | 03:34 PM
95GSRDC2's Avatar
Default Re: (iVteC_PoWeR)
i have a skunk2 intake manifold, headers, high flow cat, n1 cat back, thats about it. its driving me insane i cant figure it out, and its a stock fuel pressure regulator that bolts on your fuel rail.
Old Jul 12, 2007 | 06:26 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: please help (95GSRDC2)
Any CELs? Does the power increase at a certain RPM? Is this a recent problem or is it associated with a modification to the engine?
Old Jul 12, 2007 | 06:59 PM
1998b18c1's Avatar
have u looked at your clutch, sounds like its slipping.....
Old Jul 12, 2007 | 07:00 PM
blueintegra's Avatar
it might be ur clutch problem have u changed it ??
Old Jul 12, 2007 | 08:17 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
is it bogging?? might be a fuel injector give us more details then we can help you out more
Old Jul 12, 2007 | 08:22 PM
Default Re: please help (blueintegra)
wrong if your clutch is slipping it would rev to higher rpm's like say your going in 1st and step on it and goes to like 8k rpm like in a second then your clutch is slipping if a clutch is no good you would not go slower ur rpm's wud just fly up which results in car reving high but moves no where that's a bad clucth slipping
Old Jul 12, 2007 | 08:52 PM
95GSRDC2's Avatar
Default Re: please help (DOHCgarage919)
when i floor it it seems to have less power then if i gradually give it gas. it just started doing this recently.
Old Jul 12, 2007 | 08:58 PM
95GSRDC2's Avatar
could i just use some fuel injector cleaner? is there any way i can figure out which injector is bad?
Old Jul 12, 2007 | 09:01 PM
93projectda's Avatar
have you checked your compression/ mine did the exact same thing
Old Jul 12, 2007 | 11:11 PM
you can see if you injectors are bad when its dark you injector on the plug has a little green light if it glows green its bad if not its good but i wud do this at night so you can see and no fuel injector cleaner will not help if injector is bad
Old Jul 12, 2007 | 11:13 PM
also cud be your spark plugs same happend with mine i changed them all was good but maybe its your injectors check that first or you can buy a set of injectors plug testers to see which injectors work
Old Jul 13, 2007 | 04:19 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRDC2 &raquo;</TD></TR><TR><TD CLASS="quote">when i floor it it seems to have less power then if i gradually give it gas. it just started doing this recently.</TD></TR></TABLE>
If you gradually give it gas, does it still make high RPM power? Is there any gasoline smell in the exhaust when the car is warm? (Unburned fuel from misfiring injectors would cause this.)
I'm thinking that it could be your ignition, especially if partial throttle response is fine but WOT is not. Check the cap and rotor initially.
layinlowon14s
Mar 27, 2007 12:29 PM
cyrix12
32
Oct 24, 2006 07:42 AM
Maxime
Jul 10, 2005 05:46 AM
civicboisi
May 9, 2002 05:51 AM
