Question
Old Jul 10, 2007 | 03:07 AM
MechEng's Avatar
Default Question
I don't plan on using my 94 Teg until next year. Are the gas tanks steel?
Do I have to keep the tank full? If I do can I wait until winter to fill it up so the gas won't be very old when I try starting it next year.
Old Jul 10, 2007 | 03:32 AM
LordAphotic's Avatar
gasoline can last several months. even though everyone says it doesnt i had a car with the same gas sit for an entire year and when i started it ran fine... it was a 94 ls.
fill it up cause our gas tanks are steel and if you leave it empty it will rust to hell in the inside and the fuel pump will probably seize or go bad soon after you start it again once the rust clogs it up.
Old Jul 10, 2007 | 05:21 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
dump in some fuel stabilizer to be safe.
Old Jul 10, 2007 | 06:28 AM
VTEC_PRODUCTION's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">dump in some fuel stabilizer to be safe.</TD></TR></TABLE>
do it...also try and keep it in a low moisture environment and when you go to use it again use sea foam
Blue00Si
Apr 25, 2008 04:07 PM
Tyson
17
Dec 15, 2006 05:29 PM
pompom
Dec 24, 2005 02:26 PM
airikkCRX
Sep 1, 2005 06:49 PM
rasinhell
10
May 15, 2005 07:15 PM
